I did one side of side the rear brakes of my pickup today and the boot that was on the caliper had one end of the boot with a larger opening than the other. Sure looks like both ends should the same as the smaller end. The shoulder of the caliper pin that is covered by the boot had more rust than I would have expected.
I have owned the truck since it had 30K on the clock and it now has 114K. I have never done the rear brakes.
So unknown. Came from the factory with wrong boot? Someone before me did the rear brakes and used the wrong boot? At 30K I would doubt the boot needed to be changed.
This was a pad slap. When I do the pads and rotors I will get new pins and boots.
