Picked up a used 92 Toyota Pickup 2wd recently, and on the front I installed all new Timken bearings/races, new rotors, and new brakes. The caliper bolts to the torque plate with sliding pins. On the drivers side, the bushings on the upper sliding pin were completely gone, and I did notice that it was causing the pads to wear unevenly.
Could not find any bushings locally in stock, so ordered a Carlson 16005 pin boot kit.
https://www.amazon.com/gp/product/B000C00Y68/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Found a FSM on a 93 Toyota pickup that's just like my brakes, and it says to use a plastic bar to install the longest sliding bushing into the sliding pin side. Don't have a plastic bar, so what can I use to to get those long bushings installed? Going to replace all the boots/bushings, and don't want to take all day to do it.
Here is the FSM on the brake bushings/boots at the bottom of BR-31 step 4.
http://htftp.offroadsz.com/marinhaker/programi/toyota/Brake System/7-2wdfs171.pdf
