Build a table and make it so....I wish that the Rockauto discount codes were condensed into one thread instead of a new post whenever someone gets one. All you need to post is the code and the expiration date. Something like the "Post your latest XXXXX" threads.
AgreedMy wish is that everyone who gets something out of this forum donates a couple of bucks to see it into perpetuity.
Search is difficult. I’m a developer for an open source forum software and holy cow, getting search to work right and consistently is not an easy task.ease of use. I searched the other evening for a thread I use a lot. I got everything else but what I wanted. In my 30 years in forums have yet to find a search function that doesn't frustrate.
Agreed. Google makes it look simple. They have had decades and employ herds of programmers working every day to make it work extremely well.Search is difficult. I’m a developer for an open source forum software and holy cow, getting search to work right and consistently is not an easy task.
site:bobistheoilguy.com wwilson durango
You do essentially have unlimited editing abilities. When you post limit time expires, just send a mod alert and ask for more time, the edit time is very simple for a mod to change.I've always "wished" there was no time limit on editing posts, titles, etc. here.
Ahhhhh ok makes sense now and thank you for explaining that. All good then.You do essentially have unlimited editing abilities. When you post limit time expires, just send a mod alert and ask for more time, the edit time is very simple for a mod to change.
We limit edit times partially because if we didn't, spam bots would edit their post and add a link. We have seen this happen in posts that were years old.
My 2024 BITOG wish is for tighter moderation control over the moderators. Often times some of them don't practice what they preach.
Ok, I'm not getting this issue. I insert images all the time but just click on attach files button on the bottom, grab it, then hit insert. Is this an issue? I also see the insert images button up top as well that does the same thing I guess less one step?I wish for world peace, but I found the insert image button this morning.![]()
The "Attach files" button is not meant for photos, it's meant for files like pdf or zip, however we do not allow files to be uploaded. We want photos to be uploaded with the "Insert Image" button only. I'm trying to remove the "Attach files" button, but it's breaking things elsewhere. When I figure out how to properly remove "Attach files" it will no longer be an option.Ok, I'm not getting this issue. I insert images all the time but just click on attach files button on the bottom, grab it, then hit insert. Is this an issue? I also see the insert images button up top as well that does the same thing I guess less one step?
Ah ok, got it now. I also note in DM convos you can't insert images which would be helpful.The "Attach files" button is not meant for photos, it's meant for files like pdf or zip, however we do not allow files to be uploaded. We want photos to be uploaded with the "Insert Image" button only. I'm trying to remove the "Attach files" button, but it's breaking things elsewhere. When I figure out how to properly remove "Attach files" it will no longer be an option.
