It's just a joke people.....it isn't some deep philosophical delving into motorcyclist culture. Read it, chuckle/roll your eyes, get on with your day.
Always keep that last little bit unused....for when you need it. Currently no chicken strips on my front tyre, and 10mm on the rear - I really don't want to know where my front tyre is at 5mm on the rear. I usually run a size larger for that reason.
You don't need bendy bits to scrub the edge of your tires... just practice your 25 ft circles... this also works to scrub in new hoops...Chicken stripes are on a guys bike that will tell you there are no canyons around, I just ride in the city. "Cause I'm skeer'd"
If you want to make your bike turn slower with heavy steering, fit narrow bars. With the stock bars my bike has slow heavy steering, I have wide dirttrack bars, the bike is light and responsive and gives a change in riding style....wide late turn in, toss it down quick, pick it up and on the gas. For gravel roads I use the same size front and rear. I obviously have a different experience of riding than you do...so I won't tell you how to ride or how to set up your bike.The next step up in tire size will make your bike turn in noticeably slower. Even Bikes that come with a 190 rear will turn in alot faster with a 180 rear on the track. Its night and day . Bigger/Wider = not better.
Got a source for the calculations showing a tighter turn radius with the larger 190 tire?The difference between a 180/55 and a 190/50 is profile and
diameter... the 180 is bigger in diameter and sharper in profile...
the change in geometry is as follows... going from a 190 to a 180
means rake is steepen and trail is shorten which lowers the steering
effort... whereas going from a 180 to a 190 means rake is extended and
trail is added which adds to the steering effort...
190/50/17=24.480 621mm
180/55/17=24.795 629mm
1) No...Got a source for the calculations showing a tighter turn radius with the larger 190 tire?
What's the 24.xxxxx mm showing?
