Best oil for a 2021 Veloster N
I know I just made a thread but it was focused on my current oil (Motul X-Clean EFE 5w30) and I had decided it was adequate based on the replies but some conversations in the track group on FB made me skeptical again because of the lack of an SP or higher rating meaning I'm lacking the LSPI and timing chain wear from that cert (Motul is only SN)
Basically looking for a high quality oil that meets and/or exceeds the standards in the manual so when I go for warranty work I don't get screwed.
I'd like to stay 5w30 I'm hesitant to move up to 40 because there's been a couple cases of oil squirters falling out and thicker oil might not help in that sense (crazy thing to worry about but 🤷)
I'm also hesitant to go to 0w30 simply because I only drive in the summer and these cars run fairly hot and I drive fairly hard.
Attaching the Veloster N oil section from the manual and my current oils technical sheet specs
This whole oil thing has my OCD going crazy and the more research I do the further I get from making a decision
So I just found this that lists X-Clean EFE as SP?????????????
