Have you looked? Just go to the UOA section and do a search. Every Motorcraft 5w20 UOA you'll see is outstanding.quote:
Originally posted by bottgers:
I haven't seen the numbers for the Motorcraft ...
Maybe he chose Motorcraft because every single Motorcraft 5w20 UOA has been outstanding.quote:
Well?
Here is a Pennzoil 5w-20 UOA thread with another linked in it where both thinned quite a bit at relatively low miles .quote:
So has every single UOA I've seen for the Pennzoil.quote:
Well?
As was pointed out in that thread, Blackstone's comments about this oil thinning to a 10w were completely wrong. It was solidly in the middle of the 20 wt range. And since we didn't have a baseline VOA of this particular batch, we don't actually know how much THIS oil thinned at all.quote:
Regardless to the comment made by Blackstone you choose to refer to one of the oils there finished at 49.5 and the other at 49.4 for right at 7.1 cSt .quote:
Motorcraft 5w-20 is now $1.44 at Wally World in Northwest NJ.quote:
Originally posted by dheel:
Don't think local Wal-Mart has the Motorcraft, believe the Walmart in larger city not far from me may have. Where is it 1.42 at? Thought someone posted it was a little higher than that at Walmart. Thanks again.
Wow! I'm in Sparta also and looked at Wally World in The Trade Zone in Mt. Olive and it was $1.82 last month, up from $1.77 previouslyquote:
Originally posted by Bror Jace:
[QB] I know why I would pick the Pennzoil or Chevron 5W20 for a Honda vehicle, both have a lot of moly (~200PPM) which is similar to, and probably more compatible with, the additive package of the factory fill break-in oil ... which has close to 1,000PPM of moly.
Motorcraft uses no moly but significantly more boron. I agree that it's very good stuff (does anyone make a bad 5W20??) but if I had a new Honda, I'd prefer to use a moly fortified oil exclusively ... at least for the first year or two.
Does anyone know if Kendall 5w20 contains lot of moly?
Are you so sure that Motorcraft 5w-20 doesn't have Moly? I think maybe it does now.quote:
