5W30 will serve you well, if it were mine it would have ESP 5W30 in the sump.
OP hasn't responded. Good job, you spooked him. Now we won't hear from him until 2042!I think we should be understanding of new members here that create duplicate threads.
But, seriously. Two Thousand and Eight.
Did you just stumble upon your login info?
16 days after you joined BITOG, stock markets around the world plunged amid growing fears of a “Great Recession”, fueled by the 2007 subprime mortgage crisis.
No codes ....... smooth and quiet ... I run a mopar 339 filter or mobil 113a
nah, for real?Toyota electric oil pump
Really??OP hasn't responded. Good job, you spooked him. Now we won't hear from him until 2042!
I’m sure there are.
Probably in the same places as the Toyota electric oil pump that’s calibrated for a 20-grade.
As I noted, unrelated to the OP's vehicle and just as significant as the mythical electric pump.
OBD Fusion?
OBD Fusion?
When did 10.3 cSt become thin? Pennzoil Platinum 5w30 is 10.3one point to note,there are thinner 5w30 oils (like pennzoil platinium) and thicker 5w30 oils like the euro versions, read and learn the specs and compair to your needs.
This is on the shelf right now. What happens with Gf-7 is not our concern right now.the Pennzoil Platinium 5w30 SQ,Gf-7 5w30 is 9.8 @100c and 53.9 @ 40c,,I think the reasoning is the resource conserving ( RC spec) ,the Euro oils do not have the RC spec, and they have a higher hths rating,that is related to the thicker viscosity ,but still in conformance to the J-300 chart so it seems.
I went to 5w30 and my 2019 RAM never noticed it. I even posted the engine data before and after.I have 2017 Ram 5.7 Hemi and just reached 100,000 miles. I will be doing my own oil changes now that the extended warranty has ended. I want to switch from 5w20 to 5w30? Will it set off the “check engine light?” Will the engine explode? Lol Any advice or insight would be greatly appreciated.
10.3 is a thin 30 grade, when there are Euro 30 grades that are closer to 12.When did 10.3 cSt become thin? Pennzoil Platinum 5w30 is 10.3
Those are 0w30s10.3 is a thin 30 grade, when there are Euro 30 grades that are closer to 12.
There are Euro 5w30s that are on the thick end of the 30 grade range too, such as ESP 5w30, Pennzoil Euro L 5w30 and Amsoil Euro 5w30Those are 0w30s
