I'm running commercially available B99 in my PSD's, 7.3's. It has been in the low 30's (*F) for the past few days, and is colder now (snowing). I haven't added any additives yet, just fuel straight from the pump. Normally I always have the trucks plugged in, however I normally don't drive the newest truck as it is a toy really and I forgot the plug it in when I put it away after the last trip. At any rate, I plugged it in for about an hour which really isn't enough to do much, block was still cool to the touch. Truck started fine, bit of a lope idle which is common to HEUI engines in cold start situations. It did smoke for about 1-2 minuets and then cleared right up. I'm impressed, I figured without any PPD added it would be difficult to get it started.
I also have a 5 gallon fuel can of B99 in the garage I've been using in the heaters, also no problem with it either. I did notice a few "floaters" on the surface of the fuel when I opened the lid, however not nearly enough to cause a filter to plug.
As a side note, I still haven't had a chance to finish tested the Lubrizol additives for biodiesel. I have the fresh fuel samples and I've got the freezer setup, just need time to mix and watch. I'll get there.
