Will be doing an ATF change shortly (pan drop)....in the 03' Ford Focus. I've got about 41K on the last Mercon V fill.
Was considering either Amsoil, continuing on with Mercon V, or Mobile Synthetic ATF.
Decided to go with....Mobil Syn ATF.
The main reason I chose Mobil..... is price. Amsoil, although I consider it a top-ier syn ATF,....was the most expensive, and a bit of a bother to obtain.
Motorcraft Mercon V ATF (can be obtained at O;Reilly's) for $4.99 a quart.
But Mobil Synthetic ATF...can be obtained locally for just just a $1.50 more than MC Mercon V....at $6.49 a quart...a real bargain IMO.
Since a fellow BITOG'er, tig.... uses it on all his Fords, and has not had a transmission failure yet... I felt Mobil Syn ATF and came highly recommended...and was well priced as well.
Any thoughts on this decision...would be welcome.
