Re: 2004 Grand Marquis LS Rear Differential Fluid, ATF...
Recently bought the above referenced car at just under 69,000 miles. Manual says 80w90 for rear diff fluid. Numerous sources say it's okay to use a synthetic 75w 90, taking about two and a half quarts.
I'm near certain my car doesn't require an additive. Does anyone know for sure? My mechanic will be able to tell for sure when the car is up on a lift. A number of the full synthetic 75w 90 fluids say they've the limited slip differential additive already in it. Is harm done using such a fluid on a car not requiring it?
Any suggestions on which 75w 90 brand to use and those to stay away from? Is Lucas a good option?
Is the Fel-Pro RDS 55341 gasket cover a good option? Two different Ford parts departments told me there's no OEM for this part and said to use RTV, which I sense isn't as good as the Fel-Pro option with a good quick dry sealant. Please advise.
The ATF on the car had a dark Robitussin color upon purchase. Ever two weeks with the car warm, I'd suck out about a quart and a half of ATF, replacing it with the Ford approved Mercon V put out by Walmart Supertech. I did this eight times. Is it a good idea at some point within the next ten thousand miles to do a drop pan ATF and filter change as well?
My other planned maintenance issues will be the spark plugs (going with stock Mororcraft), gas filter (looks like it was already changed and will be changed again with the OEM part). I replaced upper and lower hoses and did a braking system bleed. I've done the power steering fluid via the turkey baster method. Serpentime belt to be changed as well.
For the engine oil, I'm using Walmart full synthetic with a Motorcraft filter, every four months/about 4,000 miles.
