Well I got out and washed and clayed the little PU today. I applied a paint cleaner, then hit it with a coat of 476S. That stuff is a PIA to remove. When I applied it I get these little white wax specs the size of a pin head. Then you wipe it on and it appears to be skipping spots, but I'm 100% certain I hit those spots. When it comes time to wipe the wax off these little pin heads are a royal pain in the butt. The wax is dry and ready when I wipe it off.
Any tricks for using the stuff. I'm applying by hand with a sponge applicator slightly damp, and using MF towel to remove it. I'm in the shade of a carport out of the sunlight. TIA
