For starters, we all know and probably agree that everyone's definition of a "better investment" is also subjective. That's probably the main driver why people buy and use the products they do in all aspects of their life.That's subjective.
I'd like to put the shoe on the other foot....
-- prove that the better filter is an actual, *quantifiable* "better investment".
Not just "because it's only $5 more, I can justify it".
As far as mechanical wear, there are scientific tests and facts that prove that higher efficiency oil filters results in cleaner oil, which then results in less wear. There are absolutely no studies that proves that dirtier oil caused less or the same level of wear if all other factors are held constant - none. I'm still waiting for someone to post up those test study results that prove it. I go by facts, not feelings.
Someone saying that "an oil filter efficiency doesn't matter" is pretty much basing it on "feelings" because cars don't blow-up before 250K miles rolls around, or it doesn't matter because the car will rust out or get T-boned and totaled before the engine wears out. All of that is just basically straw man arguments. That's kind of like saying smoking won't hurt your health or impact your life because if you happen to make it to 85 years old and can still walk around while smoking your whole life, it doesn't matter anyway because we all end up in the "junk yard". I don't operate that way, but along the lines to strive for the best path forward thinking/knowing the path I choose might result in a better long range outcome. I feel the same way about maintaining my vehicles.
Many people blurt out in these threads that "The air filter is the most important filter, and the oil filter doesn't matter". Yes, I agree that comparatively the air filter is more important, but it doesn't mean that the oil filter can't also help in mitigating less engine wear - it's all about mitigation. The air and oil filters are a team working together, not stand alone ways to mitigate wear. What if the air filter really isn't that efficient, or what if there happens to be a tear in the media or a leak on the seal and more dirt gets into the motor than you believe? The oil filter can be though of as the "back-up" filter to the air filter. If something does get by the air filter and into the oil, then guess what ... the oil filter is there to catch it. And obviously, the air filter can do absolutely nothing about any contamination in the oil, regardless of where that contamination came from - and not all of it comes in from the air intake path. What's wrong with having a high efficiency oil filter to play that role to ensure the oil stays as clean as possible? All it will cost you is one less Big Mac ... another good reason to go "hog wild" on an oil filter. And besides, a better oil filter might do more for the engine than a Big Mac does for the body.
What data? ... that cars are still "running good" with lots of miles on them? That's hardly scientific. I want to see scientific data that says cleaner oil does not result in less wear in any machine device that has an oil film between moving parts. Where are those test results?I'm all about the "feel good" aspect,
But when you look at the data from a *purely objective* standpoint, there's little reason to justify it.
