A few years ago I was running AMSOIL Signature Series 5w30. I was mistakenly under the impression that it met API SP. When I found out it did not, I called AMSOIL technical support to find out why. Tech support told me without equivocation that AMSOIL strongly disagreed with the API on certain parameters and max phosphorus (ZDDP) was one such parameter. They told me they didn’t believe an oil could provide adequate protection at the current levels, so they had more anti wear additive than allowed, hence no API cert. Sounds good right? Well, those phosphorus levels were set to protect against catalytic converter poisoning, so maybe not on a holistic level. Now I have seen AMSOIL Signature Series 5w30 VOA’s all over the place the last few years, in terms of phosphorus. Some show phosphorus in the 630 ppm range and some in the 850+ ppm range. Does anyone know what the testing for API consists of in regards to max phosphorus? Is the manufacturer required to submit so many random samples for analysis, etc.? Has anyone else received the same info from AMSOIL tech support?
