Amsoil EFO 0w40 Euro Oil
Is there any distinction between how those interact with ethanol or its byproducts?
Esters are basically alcohol and acids. They are more prone to dilution and white sludge caused by ethanol. Of course, there are other variables, like VII etc.
In my opinion, the safest bet is a grade bump in E engines with no or fewer esters.
Curious if anyone on this forum as any experience with amsoil euro 0w40? I live in Canada and have been using castrol 0w40 in cooler weather and motul xcess gen2 in warmer weather. In my area I can now only get castrol 0w40 SP and the specs/make up do not appear to be as good as what the SN version was. Did some research and came across amsoil 0w40. My car is out of warranty and so builder approvals don't concern me as much as knowing the oil is of good quality. I know amsoil lacks when it comes to builder approvals. What I found intriguing about amsoil 0w40 was that in many ways it is similar to castrol 0w40 SN. 25-50% pao, good pour point, HTHS of 3.7, KV100 13.3. All good specs imo. The noack is on the higher side and I do drive a mk7 golf R stage 2, however, I clean my intake valves every 25-30k km. Anywho, just curious if there is any experience out there with this oil. thx in advance.
I also considered castrol 0w30 but my tuner recommends I stick to 40wt.
Holy cow. Are you getting enough buildup in that time to bother? Mine looked pretty good at 75k mi when I had them done in my Sportwagen. I can't imagine why the Amsoil product wouldn't be excellent.
Lol not really to be honest but I don't mind doing it. Kills a day plus I like working in the car. But yeah after 25-30k don't really notice much for build up. I also keep my oci short sure that helps a little.
Yeah I decided to go with amsoil. Just don't seem to be a popular choice but I get it at a good price so I thought why not. It's also out of warranty and tbh I don't concern myself with approvals.
In your area? Walmart and Canadian Tire both carry Castrol 0w40 SN made in Belgium but only in 946 ml bottles if I'm not mistaken. Maybe look again. Even the Castrol Euro 0W30 should also work, I believe it's HT/HS is sufficient.
You are correct I can get Castrol 0w40 in 1qt bottles. However it's far more expensive to buy it by the qt. I can get amsoil cheaper. 0w30 would work but my preference is to stick with 40wt if easily accessible. Thx
I'm thinking the HT/HS is more important aspect than grade. Aren't they both around 3.5? If so then not a problem or am I off base here? Cheers..
Not disagreeing with that I concur, however, the amsoil hths is 3.7 which from my research is a little higher than Castrol. Could be wrong just what I read. Either way the amsoil is the better price and similar if I had to buy 0w30 from can tire unless it was on sale.
Well maybe Black Friday they'll be reduced but anyway Amsoil is very good stuff, I use the 5w30 SS a lot. Good talking to you, so long for now.
What's your favorite oil for a tuned motor on e85 these days? Besides HPL the other high HTHS options seem to be dwindling in availability.
I've been using Pennzoil Platinum Euro 5w40 with E60 on track, which I would consider a "Low or no ester" oil, being a Grp 3+. Although, my motor has very little blow-by and fuel contamination (430f flash point), it shears from a light 40w to a heavy 30w, even with mostly being driven short trips. I change the oil every 4-6k km and get iron wear in the 5ppm/1k mi range. Latest UOA had 2 track days and 90% city short tripping where oil barely gets to temp. Not a bad result for a cheap and plentiful product.
HPL Euro 5W40 has stayed in to close to being in grade (12+ cST) for me with lots of track use. It's the best oil I've used.
I'd agree with blackstone, iron wear seems high. This result seems consistent with most of the used oil analysis I've seen with cars on ethanol.
Their dilution analysis is known to be problematic, I would stick to the assumption that track driving is a high-dilution situation.
I don't find your HPL used oil analysis to be very compelling. Your recent HPL intervals have Fe/1k increasing significantly compared to when you were doing shorter intervals. And like @Nathan pointed out, you've had one complication or another with most of the recent data. Very hard to draw a conclusion from your testing tbh. From what I recall, you have to use E20 to get the unitronic tune to not pull timing?
Cylinder/ring wear usually goes up significantly with e30+ from the studies I've found.
The Fe/1K miles is still below 5ppm/1K miles, lower than the OP's results here at 2x the mileage. My wear is likely from the intake issues I had vs. anything else, just my hypothesis here. Hard to argue with an oil that stayed at or above 12 cSt after 8.5K/8 track days. I'd call that v. compelling looking at lots of used oil analysis from folks tracking their cars. Look at the mid-year sample...~4K miles and similar wear value for Fe than the end of year/2x that mileage so no better at half the mileage/track days. I'd just say my car's engine sits around 2-3 ppm Fe/1K miles normally and the biggest spike I saw was the one after my intake tube was found to be dusty which makes sense.
The Fe/1K miles is still below 5ppm/1K miles, lower than the OP's results here at 2x the mileage. My wear is likely from the intake issues I had vs. anything else, just my hypothesis here. Hard to argue with an oil that stayed above at or above 12 cSt after 8.5K/8 track days. I'd call that v. compelling looking at lots of used oil analysis from folks tracking their cars. Look at the mid-year sample...~4K miles and similar wear value for Fe than the end of year/2x that mileage so no better at half the mileage/track days. I'd just say my car's engine sits around 2-3 ppm Fe/1K miles normally and the biggest spike I saw was the one after my intake tube was found to be dusty which makes sense.
I'm not doubting HPL is a fine product, but you replaced over a 1/3rd of the sump with fresh oil on that 8.5k change. Your results with regular group III HC oils were even better, <2 ppm/1k on those 2x track day changes. My takeaway from that is I'd just change it 2x as often with oil that's 3-4x cheaper. Expensive oil is good, but fresh oil is always best.
That said, I would love to see HPL results on a car with significant alcohol usage. MSH had some really good (in the information sense) used oil analysis:
I suspect those results are typical from an EA888 on significantly higher ethanol and boost. 3k intervals, viscosity wasn't far off from what you're seeing on HPL (though admittedly he's using 5w50 mixes), but iron wear is way up. Nathan's S55 has iron-coated cylinder walls and since it seems his UOA is for 4150km, that's 8.5ppm/1k miles. Personally I would avoid that combination of driving, fuel and oil long-term.
@scrllock here are just my data including track use, I went back to my notes and cleaned this up a bit. The one thing to keep in mind on those earlier track day changes with low iron numbers on regular ol' oils is that I was a n00b and driving on all seasons just getting my feet wet on the track. 12/20 oil change - first time on track, 1 actual day (4x24 min sessions that event due to some brake issues [street pads]). Hard to compare that to 8 days of more advanced skill level driving this year driving where I'm now pushing it at a decent clip. As someone said, my data are a bit challenging b/c lots going on/not consistent/layers of things that both increase/decrease the results but it's what I have. I'd wager than the HPL will look better back to back with all other variables constant vs. either of the Liquimoly oils sitting on my work bench ready for changes in my other vehicles coming up.
Would you say that flashpoint is not an accurate indication of whether or not there's fuel contamination?
If VOA flashpoint is 455f and my sample reads 430f, can't be much fuel in there, me thinks.
Note: I'm using a catch can that just collects water, so far.
That basically is how BS does this - they infer %fuel based on flash point, I'd say 430 is pretty high/good/indicates min. fuel in your oil. Best is gas-chromatograph analysis for the volatiles if you want a real value.
