- Joined
- Aug 6, 2021
- Messages
- 355
Hey Harry Whats about your Civic? So you have one Million Kilometers in it now?
What do you mean by magnetic filtrationThankyou for those words of wisdom billpace1956.
If you want to keep your car for many years, you should probably be using Amsoil . I believe that it is the finest oil on the planet.
Don't underrate the addition of magnetic filtration, sure it only removes ferrous particles, but aren't those the little rascals
that cause a lot of wear? It will protect all the softer metals from wear and minimize oil oxidation.
Very interesting I’m going to try find some for my 2010 Crown Victoria I’d love to see how far I can push the car before catastrophic failureMagnetic oil filtration will remove a lot of the wear iron from the oil stream. The removal of the hard, abrasive iron
will greatly lower the wear on all internal engine components. While magnetic oil filtration will not directly remove the softer metals,
It will remove the iron that will cause their wear.
Examples of magnetic filtration include a magnetic oil drain plug, a wraparound oil filter magnetic array of neodium magnets or
just some loose magnets applied to the outside of the oil filter. This is by no means an exhaustive list of possibilities. I understand
that some folks actually put magnets inside the oil filter. You can actually buy a filter that already includes internal magnets.
I use Filtermag magnets on my oil filter, they are very effective.
I know that Honda puts a magnetic drain plug in their transmissions, other manufacturers put magnets in their transmissions.I’m totally agreeing with you. I just find it weird that manufacturers don’t implement any type of magnetic filtration in their expensive engines. 95% don’t even come with a simple magnetic drain plug.![]()
Could it be from long-term exposure to coolant? Are bearings made of iron along with copper and lead? Bearings are usually what I notice get eaten by coolant.The long term engine wear is continuing to creep upward.
100k miles ago, the Fe wear was reasonably low; around 1.5ppm/1k miles.
Now, over the last several OCIs, the Fe wear is getting very pronounced.
I'm not intimantely familiar with this engine series; is there a timing chain with steel guides? Something seems to be signaling that wear is escalating, fairly strongly.
The whole dirty thing bugs me.............too dirty for a particle count?
Contaminated?
How could this NOT impact dissolved metals?
I would say, run again and sample cleanly. That should be telling.
This is interesting. Are you still running Gumout?I ran an experiment this oil change interval. Every gas fill-up received a bottle of Gunout Regane High Mileage Fuel System Cleaner.
I wanted to see what effect it had on the oil. Apparently, it liberated some contaminants coating the inside of the engine, this was minimal
however, it may be the cause of the "dirty" rating from Blackstone labs.
