Dodge Durango 3.6L - HPL CK-4 5w-20 - 16,232 miles on oil - 190,400 miles total
wwillson
Staff member
Colorado
This sample from the Durango has been in service for almost 14 months and 16,232 miles. The oil is HPL 5w-20 HDEO. As I stated in the previous UOA post, my son and DIL own the Durango and drive about 80% in town and 20% highway. Many more short trips than how I used the vehicle. There was about 1 quart oil consumption in the first approximately 15,000 miles. Oil consumption is unusual for this engine, unless it has a lot of cold starts. It now has a lot of cold starts, to which I attribute the increase in oil consumption.
The viscosity, TBN, and oxidation are trending almost the same as the previous oil change, which surprises me. I expected so see more detrimental effects of short tripping, but I see none. We might also expect more wear metals because of the high number of cold start, but that isn't happening.
Overall I think the results are outstanding given the large number of cold starts and short tripping especially during the cold winter months.
Previous UOA: https://bobistheoilguy.com/forums/t...-474-miles-on-oil-184-710-miles-total.387900/
Google Docs spreadsheet here for entire UOA history
Sample Information
Sample DateMarch 15, 2022September 5, 2022April 19, 2023June 13, 2023October 28, 2023January 1, 2024January 9, 2024September 22, 2024February 22, 2025
Machine Age miles141,500147,000152,000158,700168,000173,300174,236184,710190,400
Oil Age miles1,5007,00012,00018,70028,00033,3005010,47416,232
Makeup oil quarts0.7500.75
Filter Age miles1,5002,0005,0006,7005,0005,0005010,4743,868
Oil Changedyesnonononoyesnonono
Filter Changedyesyesyesyesyesyesnoyesno
BrandHPLHPLHPLHPLHPLHPLHPLHPLHPL
Viscosity5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO
new formula
Wear Metals(ppm/1k)
Iron69151723334(0)19(1.4)22(0.52)
Chromium<1<1<1<112011
Nickel<100<1<1<10<10
Titanium<1<10<1<1<10<1<1
Silver0<100000<1<1
Aluminum24158127109
Lead10003<1<101
Copper31657269646585449
Tin<1000<1<1<10<1
Vanandium0<10<1<1<1<1<10
Cadmium000000000
Additives
Boron2200116184>1
Barium000410002
Molybdenum492548600590494573579581594
Manganese<1<1<1<1<12<111
Magnesium109198111581059998113110089741114
Calcium243124582767264523402637253225452782
Phosphorus1094102410951041855108911449101081
Zinc117612711411127111291404128411941460
Contaminants
Silicon121318172022132017
Sodium0354161941417
Potassium022343<132
Fuel %<1.0<1.0<1.0<1.0<1.0<1.0<1.0<1.0<1.0
GlycolNEGNEGNEGNEGNEGNEGNEGNEGNEG
Soot%0.10.10.10.100.10.10.10.1
Fluid Condition
TBN16.810.89.288.1167.7615.038.947.16
Viscosity9.41010.411.612.613.210.410.411.9
Oxidation0 (39.7)12(51.7)14.3(54.0)21(60.7)24.4(64.1)27.1(66.8)0(39.5)15.5(55)19.7(59.2)
On the last filter change, did u cut open the filter? How did it look? It should be clean based on filter changes.
What oil did you run in the first 141k miles?
Started running HPL at 111,000 miles. The usual was 10w-30 HDEO in the summer and 0w-20 or 0w-30 in the winter.
Remembering you had to change the oil cooler and capless fuel fill, any other problems in 190k? Impressive for a crappy Durango!!
I changed the plugs (third set) and injectors when I did the oil cooler. The dealer did the first oil cooler under warranty and changed the plugs then. Radiator and A/C condenser have both been replaced, but not much more than that. Tires even lasted to 90k plus, but that's the fault of the guy driving.
Yes, click on the link for the previous UOA above.
Those engines are very easy on oil. My daughter had a 3.6 and I changed it every 10k with mostly pennzoil and a super tech filter. Never used oil and it was still newish looking.
0.52 ppm Fe/1k @ 190k miles. Just wow. Sure, this oil thickens some with use; all of them do. For this oil, we know it’s not caused by something bad. I’d swap one quart out for a fresh one every 7.5k or so to keep the viscosity down and TBN & additives up, and go til iron wear starts to show a statistically significant shift, which would probably be once total iron is around 100.
Either way, @wwillson, the current method of top-up and UOA is obviously working very well for your kids!!
Am I correct to assume in the Feb 22 2025 data point, 0.75 make oil was added, mixed and then the oil was sampled?
@wwillson, why do you suspect cold starts increase consumption?
My observations have shown that when it has a lot of short trips, the oil consumption will go up. The first 100k miles were probably 70% trips < 10 miles and I would regularly have to add some top-off oil. Maybe at the rate of one quart every 10k miles. When I would do a lot of long trips, which was what most of the miles were between 100k and 175k, it consumed almost no oil. Now that it's back to short tripping, the consumption is around one quart every 10k like clockwork.
