2017 Ford F53 6.8 V-10 Kendall GT-1 5W-30 4805 miles
USA
Code:
Miles on lube 1113 4883 5226 4478 4765 3208 5157 4465 4805
Miles on Unit 1113 5996 11222 15700 20465 23673 28830 33295 38100
Fe 34 21 14 14 21 10 12 7 9
Ch 0 0 0 0 0 0 0 0 0
Ni 1 0 0 0 0 0 0 0 0
Al 7 4 4 4 4 3 2 2 1
Cu 22 7 3 2 3 2 1 2 2
Pb 0 0 0 0 0 0 0 0 0
Sn 0 0 0 0 0 0 0 0 0
Cd 0 0 0 0 0 0 0 0 0
Ag 0 0 0 0 0 0 0 0 0
V 0 0 0 0 0 0 0 0 0
Si 88 46 24 21 19 17 18 14 16
Na 10 5 4 3 3 3 4 5 3
K 8 3 2 2 3 0 0 0 0
Ti 0 85 93 95 99 105 10 1 29
Mo 85 24 17 17 17 19 150 142 72
Sb 0 0 0 0 0 1 1 0 0
Mn 4 1 0 0 0 0 0 0 0
Li 0 0 0 0 0 0 0 0 2
B 211 79 64 78 76 125 55 55 71
Mg 15 12 11 9 11 11 379 356 730
Ca 2068 2161 2134 2175 2524 2536 1631 1270 1153
Ba 3 0 0 0 0 0 0 0 0
P 757 679 680 666 720 795 814 678 671
Zn 760 797 840 770 818 898 958 769 797
Fuel dilution 2.3 2.8 2.6 1.8 2.2 1.5 1.6 1.5 2.0
Soot  Water  Vis, 100C cSt 7.4 8.6 8.9 9.1 8.9 8.9 9.2 9.0 10.0
This is a semi-synthetic oil with LiquiTech add pack. It replaced the Liquid Titanium pack which is no longer available. Looking at the additive metals it appears that the most recent change has lower Moly and Calcium but increased Magnesium and a return to Titanium. All oils since the factory fill have been in sealed packaging purchased directly from a Kendall distributor.
In any event, wear metals are the real concern and they are rock bottom. The V-10 is a tough motor (if a little thirsty).
Dang, there are some big differences in the Zinc levels in this oil over time.
That Triton needs a supercharger.
I am confused by this post. The OP is willing to spend money on a used oil analysis, but will only spring for semi-synthetic Kendall oil. I guess Kendall has some following in the diesel community, but it is not discussed that often on BITOG, at least that's my perspective. The original poster, I think, has some concerns about the add pack changing over time in this Kendall semi-synthetic oil. The poster also points out that this oil came sealed from an authorized distributor, suggesting that there are some question with oil supply, counterfeits, whatever???
Anyway, we are looking at 5,000 mile oil changes on a big, tough engine. Any oil will do the trick, but would definitely suggest synthetic. I can't see anything in the UOA that indicates that the engine is doing anything except maybe improving a little over time (ie. viscosity). I would suggest moving to a good full syn, Mobil 1 or Rotella... and save your money on all those UOA's.
The point of UOA is to develop a history so that changes can be spotted. Looking at wear metals, exactly what would Mobil 1 improve (other than ExxonMobils' bottom line)?
Wow, If this is a motorhome I didn't expect wear to be this low. This v10 is in good health & that is very good numbers.
