- Joined
- Nov 19, 2023
- Messages
- 980
Dang is this an installation defect, engineering defect, or maintenance?
cost cutting and shareholders over design and innovation. Was this not their mo back when Md existed?Boeing has had problems ever since they were taken over by McDonald Douglas in 1997. Their problems only became worse when they went insane and moved their corporate headquarters to Chicago.
I'm still really irked that Mitsubishi purchased most/all of the tooling from Bombardier on their regional carrier aircraft and did nothing with it! They had a well designed if not goofy named Mitsubishi Space Jet (MSJ) that was an improved design. They had 45 plus orders from ANA, a handful from JAL from memory and a few smaller European carriers had orders. Something like 150 plus in total. Supposedly subway and train cars were more profitable. If they had cranked these out during the pandemic airlines would be taking delivery now.The pressure should have firmly seated that plug. Not sure if the plug was defective or defectively installed by Boeing. Also consider that Alaska may have tinkered with it after they took delivery from Boeing.
Too soon to say if it's a one of or something about the plug that's across all Max. I'm inclined to say it's just this plane since Max has been around awhile.
This incident and the rudder nut aren't a great way for Boeing to start the year.
Their answer to those issues is absolutely insane. They moved HQ to Arlington so they can better lobby through regulation. Instead of fixing the root problems of their decline, they double down on their old "strategy." They became a company worried only about stock, not engineering.Boeing has had problems ever since they were taken over by McDonald Douglas in 1997. Their problems only became worse when they went insane and moved their corporate headquarters to Chicago.
Yes, mid-aft door. It blew off at 16,000ft.
It was not a door it was a panel that blew out.Of course, it is too early. But Boeing has a serious PR problem. Entirely of their own making.
It is a mid-aft door that is basically "sealed" in certain configurations, like this one. From inside, it looks like there is no door; you cannot notice it.It was not a door it was a panel that blew out.
Boeing has an epic QC or engineering failure AGAIN on this plane as it was just certified back in Oct 2023 to fly.
They might as well stop making 737 anything. They have destroyed an amazing reputation.
What ? Its called Boeing, Not Mcdonald Douglas. Boeing bought Douglas not the other way around.Boeing has had problems ever since they were taken over by McDonald Douglas in 1997. Their problems only became worse when they went insane and moved their corporate headquarters to Chicago.
Yep not to mention the 767-2C debacle and the presidential aircraft conversion bad press. 777X delays.Boeing seems to be moving along from one disaster to the next, what with continued problems with the in-service 737Max 8&9 aircraft, the never-ending certification saga of the Max 7 and 10 and the continued production problems with the 787, which by now should be a mature program free of any problems.
What a difference from the Boeing of thirty years ago, when the 777 was nearing entry into service and the 737NG program was going strong.
I'm very glad that this most recent failure didn't result in anything more than an emergency landing and a grounding until inspected of most of the Max 9 aircraft in service.
The inspections taking place support your theory. Several hours to complete and the airplane is back in service.A leading theory on airline forum is the bolts holding plug in place were not tightened down by Boeing. The plug is installed loosely by the fuselage contractor and Boeing either puts a door in the spot or finishes tightening down in the factory depending on how many seats airline wants. A fairly common procedure is B will take the plug out frequently even if it is going to be reinstalled to add access to install the interior components. It’s theorized in this case they did not remove plug to finish interior and missed tightening the bolts to spec which then loosened and there you go.
If Boeing was not taken over by MD, why did they adopt the MD logo as Boeing's new logo?What ? Its called Boeing, Not Mcdonald Douglas. Boeing bought Douglas not the other way around.
So Boeing not TAKEN OVER BY MCDONALD DOUGLAS.
The big problem always has been rush rush on the fabrication floor, have a friend that worked building 727's and has some stories.
And yeah stupid move to crime land chicago, they could have stayed put and had the same here.
If this was the first time the plane ever flew, my (uneducated) guess would be-maybe no bolts holding it in at all(?) Only the interior trim holding it in place? Is the fuselage pressure tested by the airline after all the seats & interior are in place?The inspections taking place support your theory. Several hours to complete and the airplane is back in service.
The clean edge of the remaining fuselage surrounding the hole doesn’t suggest structural failure, but a failure of the hardware holding the plug.
