Can this be avoided by disconnecting the battery?Yes your airbag light will go on BUT it will need a shop level scan tool to clear, so its a trip to the dealer or a shop, for at least a diag fee.
Scan tools with air bag diagnostics and reset are under $100 now. https://www.ebay.com/itm/284107724983?hash=item422623d8b7:g:RZ8AAOSwlEhgUFxXYes your airbag light will go on BUT it will need a shop level scan tool to clear, so its a trip to the dealer or a shop, for at least a diag fee.
My point is oce the airbag light goes on from a junk ebay clockspring you have to buy additional equipmentto fix the issue. OEM FOR AIRBAG AND RELATED SYSTEMS. I see all kinds of anti chinese junk parts posts here, but some of you are justifing purchasing an unknown quality component that literaly can kill you but you won't buy a **** wrench made in China. ***???Scan tools with air bag diagnostics and reset are under $100 now. https://www.ebay.com/itm/284107724983?hash=item422623d8b7:g:RZ8AAOSwlEhgUFxX
No its a hard code. It may go out for a drive cycle but it will go back on because abs system are extremely sensative to voltage and resistance.Can this be avoided by disconnecting the battery?
In fact, virtually the entire air bag controller is a test set for the system. Follow the manual directions fanatically by all means but I'd go with an aftermarket part.The airbag system has many internal checks to make sure everything is working. If it was broken, the airbag light would come on. Toyota charges $225 because it can.
Most last over 20 years or more. Don't think I've ever had to replace one.my OEM lasted 7.5 years and 132k miles
Toyota 2nd Gen Tacoma’s have this problem. Same with A/C resistors/plugs/harness, door lock actuators, and… well ya know, rotting frames.Most last over 20 years or more. Don't think I've ever had to replace one.
Ok, but otherwise they are pretty reliable? Worth paying the Toyota tax over the average Chevy or Ford? (sarcasm)Toyota 2nd Gen Tacoma’s have this problem. Same with A/C resistors/plugs/harness, door lock actuators, and… well ya know, rotting frames.
As long as you don’t have an ‘05/‘06 with the head gasket issue the engine and transmission are truly bulletproof.Ok, but otherwise they are pretty reliable? Worth paying the Toyota tax over the average Chevy or Ford? (sarcasm)
this is the Rockauto economy brand listing, any idea on who manufactures this brand?Rockauto.com Ultra Power for $35 is the most popular replacement option on there. Has option with or without cruise. Plus not a counterfeit.
up to 2012 modelsTacoma did have a recall on the spiral cable. Have you had yours replaced under the recall?
