M y 2nd Gen Toyota Tacoma horn has stopped working and have 132k miles on the truck from researching I've found that the clock spring is at fault and need a new one, Im a very particular in buying strictly OEM parts but viewing some How-to videos on the replacement alot of Toyota owners are using aftermarket AMAZON/EBAY part for $40 or sometimes less stating that the qaulity and fit are OEM standards, the part is 84306-0E010 i have the steering wheel controls version and an OEM Toyota is $225 I've done all the proper checks making sure the clock spring is bad, all fuses good, no 12 volts to the horn connection, relay is fine and the horn will blow if the wheel is fully turned left or right but not with the wheel straight ahead. Anyone have used a qaulity aftermarket brand ?
