ACEA C6 vs API SP (SQ)
Rochester, MI, US, World
I’m still trying to figure out what differences exist between these two specs. They seem to have a lot of the same types of tests. The one that stands out is that for C6, it is advertised as a “stay in grade” oil, meaning that some measure is in place to prevent shear. I’m assuming SP has something like this too, but I really don’t know. The only two highly available API SP oils that also carry C6 are Mobil 1 ESP 0w20 and Castrol EDGE Extended Performance 0w20. Both start out pretty thin, but I assume that neither shear very much. I don’t think either use a lot of VIIs either.
  • Like
Reactions: GW.
C6 requires the exact same LSPI and TGDI chainwear test of SP.
I was referring to API SQ. Both of these tests were made more stringent. The chain wear limits are only slightly different, but the new LSPI test is a significant improvement.
from what I’ve seen, ACEA C6 oils are made to keep their viscosity longer under stress—that “stay in grade” thing you mentioned means they resist thinning out (shearing) better. API SP oils also focus on protection and durability, including controlling shear, but the specs come from different groups and focus on slightly different tests and requirements
