Accidentally spilled water into oil! Change or not?
I would probably pull the pan off and check the main bearings for corrosion before doing anything else. If they look good, then pour the oil you drained back in and run it.
Seems like a little overkill.
I think thelostotter was pulling your leg....having you on....ribbing you; like the following:
Jack up the front end of your car and remove the front wheels. Lay a tarp on the ground beneath the engine and forward of the firewall.
Lower the car to the ground.
Open the hood and pour uncooked white rice into the engine bay. ~200kg will do.
Close the hood and let the rice absorb the water as you would a cell phone dropped in a sink.
If no rice is available just drive the vehicle.
Water and oil will separate with water at the lowest point of your oil pan when oil is cold. Find a way to siphon the lowest point of the pan or remove the pan.
If I did that, I would replace oil and filter. For less than $40 (probably less, I'm going by my oil changes) you can guarantee yourself that you don't cause issues.
Don't ask me how, but i managed to drop about 20-25ml ( 0.6 fl oz ) of water into the oil of my 1988 Ford Escort XR3i ( sump capacity 3.7L ish )
Should i change it? i only changed the oil about 1200 miles ago...
Can’t imagine how this happened but if water is allowed into the engine there is probably a fair assumption that some careless activities are occurring with this car anyway…
Run it and forget about it.
This is silly.
This is silly.
I was changig the rocker cover gasket, i opened a bottle of water and accidentally spilled some 😅
This is a very small amount of water. Just keep running it. Engines are not hermetically sealed to water. Burning gas creates water, blowby when the engine is cold condenses a small amount of water into the crankcase. In cold climates many vehicles will see water buildup on the oil cap due to the moisture in the crankcase.
Just run the engine. getting the engine oil up to temp with a working crankcase ventilation will pull all the water out in no time.
Exactly! Water is a natural byproduct of combustion.
Burning a gallon of gasoline produces 8.6# of water. Some of it is going to find its way into the crankcase.
