When I talked to Mobil 1 yesterday, they told me that MOBIL 1 SUPERCAR 5W-50 and their euro 5W-50 were different. A couple of things that they told me were different was 1200 ppm zinc in the Supercar oil and only 1000 in the Euro. If I remember correctly, there was more phosphorus in the supercar.
I should’ve asked them how long the SUPERCAR 5w-50 is good for when you track the car and daily drive it.
I have a 2022 10r80 Mach 1 Mustang with the Coyote and about 9400 miles on it, and heat exchanger for all the fluids. Everything I’ve read so far says to always change to fresh oil before you track and after you track.
I’m wondering since I’m using Mobile 1 SUPERCAR 5W-50. Would it be OK to change to that before I go to Summit Point track for about 80 minutes, on track. Then just leave the oil in for another 5000 miles or more? MACH 1 has heat exchangers for all the fluids, including the oil cooler and it holds 10 quarts of oil? So it keeps the fluids cooler. It is SUPERCAR 5W-50.
And would it be different if I was going to VIR Virginia international raceway, which is a bigger faster track?
Should MACH 1 owners change any other fluids post track time on a Mach 1?
Also, is it a great idea to change the oil pan to the aluminum one with baffles to make sure there is always oil getting to the engine especially in the corners? Is the Ford Performance one a direct fit with no modifications or should I go with some aftermarket 10 quart capacity oil pan WITH BAFFLES?
Also, I assume the aluminum pan would help to cool the oil also versus the plastic one.
Thank you.
Thank you.
