Originally Posted By: chrisri
That doesn't change the fact that every engine should wear less with Euro 40 grade than with 20 grade SN stuff...
What would be real life difference is another matter.
Not really. It depends on how the vehicles are operated. In Europe some are driven at much higher speed with engine ran at near reline some of the times so that oil temp can be above 130-140C, in North America most vehicles are running at 70-80 MPH or slower and RPM are around 3k or less and oil temp is as low as 90-100C or less. Higher oil temp in Europe and elsewhere dictates thicker oil.
Honda S2000 is a little different, they are used to track in North America as well as elsewhere by some owners, when you track your S2000 the engine speed is usually above 6000 RPM and oil temp is way above 100-110C and it needs a little thicker oil than xW20.
Honda knows and tests their engines more extensive than anybody else. They first recommend conventional 10W30 for S2000 in all weathers and all locations the first 4 years from 2000 till 2003, then they found out that some drivers drove their S2000 even in winter when temperature can dip below 0F(-18C), they recommended 5W40 for cold start. There was no conventional 5W40 back in 2004 only synthetic, and synthetic 5W40 flows faster than conventional 10W30(according to Honda). Because of this 5W40 recommendation some S2000 drivers use it for tracking and normal driving in summer, the reason is at 80 MPH the engine is spinning at fairly high 4300-4400 RPM, with ambient temperature in desert can be as high as 120F the oil temp can be above 120-130C.
Personally, I mixed M1 0W40 with 0W20 to get HTHS north of 3.3 compares with 3.0-3.1 HTHS of most conventional 10W30, because whenever possible my speed on open roads is north or 85-90 MPH and RPM is north of 4800-5000. With this high RPM I like to have slightly thicker oil.
Oil viscosity depends on how/where you operate your vehicle(s).
