nutsbolts
Originally Posted By: Johnny
Is this the add pack of the HDD 5W-30?
Calcium 1709
Magnesium 63
Phosphorus 733
boron 5
Zinc 816
The calcium, phosphorus, and zinc numbers look a little weak to me for a HDEO.
can those additives be absorbed into the jello like sludge that was in this engine?
My very first post I attached a link that I think nobody read.
I can see why I had so much sludge. http://oilanalysis.com/article_detail.asp?articleid=193
Quote:
Quoting again from the report by the Fleetguard division of Cummins Engine, “Oil samples will sometimes have several hundreds parts per million sodium, yet there will be no moisture or glycol present. The amount of sodium indicates that at least a gallon of coolant has leaked into the crankcase, but there is no sign of it (other than the sodium).” Cummins summarizes by saying, “Our experience is that the most reliable indicator of coolant leakage is the sodium level of the filter paper ash followed by the level of the sodium in the oil.” Due to the loss of sodium from oil consumption or by insoluble sodium captured by the oil filter (80 to 90 percent of the total sodium that has leaked into the crankcase in some instances), an increase in sodium in the oil by as little as 50 ppm can mean as much as one gallon of coolant has leaked into a 10 gallon (38 L) lube oil system.
Quote:
In general, glycol above 200 ppm in most cases is considered reportable. Levels greater than 400 ppm should be regarded as significant and levels as high as 1,000 ppm flagged as critical.
Thanks for your help in the past
Javier
Calcium 1709
Magnesium 63
Phosphorus 733
boron 5
Zinc 816
Javier
