My 2009 taurus calls for 5w 20 but from what I've heard, this was to increase the cafe and fuel economy. Is it okay to use 5w 20 in my 2009 taurus? I believe it's a dura tec. Anyone else use 5w 30? Does 5w 30 protect the engine better even if the cap calls for 5w 20? What have your experiences been , in this specific vehicle or engine when using 5w 30? Any benefits? A quieter engine?
Is meijer synthetic oil any good? It's only 16.49 for 5 quarts. Is it a quality oil like mobil 1 or no?
Is meijer synthetic better than a premium conventional for the same price? It's on sale. I aksed about 5w-30 because the 5w-30 meijer brand is dexos approved, whereas the 5w-20 is not, so I figure their 5w.30 formulation is better. Is it better than supertech oil?
Also, is it better than the motorcraft synblend since it's a full synthetic for a lower price? I heard 5w-30 shears to a 5w-20 anyways, so wouldn't you end up with 5w-20 anyways in the end?
meijer high mileage oil is sketchy, i think because it doens't have teh API starburst on it! Maijer conventional and full synthetic have the starburst and is AF, GF-5(etc) certified, and the 5w-30 is dexos approved and i heard dexos standards were tough to meet
why doens't the high mileage meijer brand oil have the starburst?
Because meijer synthetic is not as good as mobil 1, i heard you can only do a 5000 OCI, safely, with it, and I can use a purolator pureone (i bought one for 4.71 on sale at k mart)
I heard puro had media failure, is it all/most of them or just a select few, or should i stick to the motorcraft? I use the fl400s for my 2009 tuarus manufactured before 1/19/09 (the one after uses the fl500s, i think which is more expensive). Does this mean my engine that was manufactured before 1/19 is worse than the fl500s using engine made after 1.19.09 since it uses a more expensive filter?
Also, the purolator 20195 which the brochure said my car used was REALLY TALL. Is a tall fiter good/or mean better filtration? the proportions were really odd, whereas the motorcraft seens fairly standard sized and is "perfectly" proportioned, sort of like an oil filter golden ratio, whereas the purolator seems out of whack and is too tall
