Only had two part numbers, 5.48 a piece. They did add the pf64 equivalent. The adbv almost looks blue/purple. It's not like the acdelco color.
Bargain even when the OLM cries at 7500 !Man..... I have a hard enough time going 10K
The box did say 20k or 1 year, so what I think is going on is this the Mobil 1 filters that champ used to make. If so not a bad deal.Anyone that would run an oil filter or oil for 20,000 is crazy. 10,000 is bad enough but 20,000 takes the cake. I know that AutoMechanic will not be using that filter at least not for 20,000 miles.
I have no problem with the e-core. It is now the default style for cartridge filters in most vehicles, so being used in a canister filter is not a big deal for me.Looking forward to the first c&p. I would consider using as long as it doesn't have the plastic cage for support.
My "speculation" based on the image on the box and that 'some' ST applications posted have gone to ecore with metal endcaps and poppet bypass, that's what will be found. If the combo valve removed from all applications, that would be an improvement. Make it a 20k mi. filter? Meh for me.I would consider using as long as it doesn't have the plastic cage for support.
