you might want to search UOA forum for this engine, I do no recall seeing any reports for it, just 1.5T and 2.0T.Mine does not have a turbo
I once had TBI in an old Chevy pickup. The parts guy said "OH, you have Toilet Bowl Injection". Which was very appropriate.Multi-point is port injection, the name was designed to differentiate it from the TBI setup that Honda used previously.
Im not finding much on the naturally aspirated 2.0 from Honda under this website much at all. Hence the origination for the thread to being with. I guess I'll have to join a forum to find UOAs.you might want to search UOA forum for this engine, I do no recall seeing any reports for it, just 1.5T and 2.0T.
Do your research, the 2.0 is a NA port injection engine, does NOT have the OD issues that the 1.5t, a Direct injection Turbocharged engine sometimes has. A good 0w20 like Mobil1 0w20 EP and factory filters will work just fine. The MM does not measure oil condition, it's essentially a " best guess " algorithm designed to minimize costs for the owner and get the car through the warranty period. If you want to keep it long- term, shorter term OCI's between 5-7k will be beneficial. It has been suggested to me by knowledgeable Honda professionals, a spill and fill on the CVT every 30k is a prudent practice. As in all vehicles, pro-active maintenance pays off in the long-term. Not just my opinion, but that of people I trust who have serviced Hondas for many years.Honda recommends viscosity 0w-20, but does not require unlike other fluids.
These engines could be big fuel diluters, and 5w-30 might be more appropriate to offset the effects of lowered viscosity. I would do UOA and go from there
Read my posts. My research involved UOAs that showed 5% oil dilution in m1 EP 0w-20 with 3.4k miles. And I drive 90% highway. Take a look at UOA forums to see what kind of viscosity drops and fuel dilutions are seen in Honda 2.0T. I dont know about non turbo engineDo your research, the 2.0 is a NA port injection engine, does NOT have the OD issues that the 1.5t, a Direct injection Turbocharged engine sometimes has
Why not do what your owners book says...So this is going to be my next commuter until I retire at around 12 years/175kmi of usage. The motor is the naturally aspirated 2.0 K20C2 variant. I planned on running the oil out until the Maintance Minder tells me to do a change out, but seems most say 7500mi max per OCI. Here are my questions:
Anything else you guys recommend, please do tell!
- What OCI should I run on the motor?
- What oil should I run? What oil viscosity should I run? The owner's manual states 0w-20 only, as far as I can tell.
- OEM filters Id assume? Looks like some dont like it because its a Fram?
- Im going to dump the FF oil at about 2500mi give or take, does that sound okay?
- I saw some people NOT resetting the MM in between OCIs... why? They would do it every other OCI to keep the MM on track?
thanks!
The reason was explainedWhy not do what your owners book says...
I am sure that they know more than Honda on a car they built....The reason was explained
Was responding to the OP who has the 2.0 K20C2 NA engine. The 2.0t does share the OD issue with the 1.5t as do most DI engines with forced induction. The 2.0t is not available in base model Civics only in the Type R, it was available in Accords, but not anymore. The 2.0 NA is also used in the HRV'S. It's a purely normally aspirated and is generally considered a extremely reliable engine with few issues.Read my posts. My research involved UOAs that showed 5% oil dilution in m1 EP 0w-20 with 3.4k miles. And I drive 90% highway. Take a look at UOA forums to see what kind of viscosity drops and fuel dilutions are seen in Honda 2.0T. I dont know about non turbo engine
Good reccomendation, although I went back to the OEM filter after most of the brands I trusted sold out to Mann-Hummel and got quality/consistency issues. Other than motor oil (I've used Mobil1 synthetc products for at least 35+ years, always API rated GF-6 Dexos1Gen3 which is what Honda reccomends) Other fluids, Transmission, coolant, differential (CRV) and coolant are always genuine Honda. I used the M1 M110A filters when they were made by Champion, now actually Purolator (Mann-Hummel) now I've stopped obsessing and worrying about filters and just use the Honda A02. I also use Honda intake and cabin filters. As I have extended Hondacare, at 76, I have a trusted dealership do my servicing. The CRV is coming up on its 4 year brake fluid service, it only has 11k on it. I still change my own air filters though, wipers too. Forgot to mention, per Hondas reccomendation, Toptier fuels only.Five pages of a mind-numbing thread here
Use a quality 5w20 or 0W20. Nothing special or robust the first change. You might want a better filter than the Blue Fram. Mazda O.E Tokyo Roki or ??
OCI to how you drive.
Short trips low mileage 4-5k mi OCI; Mostly highway use OLM or 7500+
Not a troublesome engine.
Oh, and 2k on the FF + or -.
On my 2007 Honda Accord with a 2.4 I had 386000 on it and used a FRAM filter...Just use a name brand filter and you will be fine...I used Mobile 1 oil and a FRAM tufguard 7317 filter...Thanks guys. I’ll be using the OEM filter for sure
Which M1 oil out of curiosity?On my 2007 Honda Accord with a 2.4 I had 386000 on it and used a FRAM filter...Just use a name brand filter and you will be fine...I used Mobile 1 oil and a FRAM tufguard 7317 filter...
Advanced fuel economy one...Which M1 oil out of curiosity?
I’d assume the car will tell me when to get the service done? The CVT fluid, is what I’m talking aboutI have 218,000 km on my 2016 Civic LX with the 2.0 engine and I have used a few different 0w20 synthetics since I bought the car with 130,000 km on it. I follow the maintenance minder, usually changing when it hits around 10% or so. By that point it's usually about 14,000 to 16,000 km. It doesn't consume any oil and over the last 10,000 km it has averaged 5.3L per 100km (44.3 MPG) Honestly, these engines are nearly bulletproof, there are many of them with 300,000 miles or more out there. The more important thing to make sure you do is change the CVT fluid regularly.
Just changed mine on my 21 hrv and it was very easy.. I would use only Honda OEM fluid....I changed mine at 30000 miles and will change every 30000 miles after that.Fluid looked great on the first change...I’d assume the car will tell me when to get the service done? The CVT fluid, is what I’m talking about
