So this is going to be my next commuter until I retire at around 12 years/175kmi of usage. The motor is the naturally aspirated 2.0 K20C2 variant. I planned on running the oil out until the Maintance Minder tells me to do a change out, but seems most say 7500mi max per OCI. Here are my questions:
thanks!
- What OCI should I run on the motor?
- What oil should I run? What oil viscosity should I run? The owner's manual states 0w-20 only, as far as I can tell.
- OEM filters Id assume? Looks like some dont like it because its a Fram?
- Im going to dump the FF oil at about 2500mi give or take, does that sound okay?
- I saw some people NOT resetting the MM in between OCIs... why? They would do it every other OCI to keep the MM on track?
thanks!
