2024 Chevy Tahoe LM2 3,000 miles/65 hours on oil - 3,000 total miles/65 total hours - HPL 0w-20 Dexos D
Happy to see GM still offering a diesel in 1/2 ton segment. I see what you see on that filter & is a fresh reminder to replace the filter on a shorter run to get rid of that debris within early break-in period. I'm going to check out that PPE oil filter site, sounds interesting. Great pics. Any oil change plans on this Tahoe w/that HPL? Just curious, Thanks for sharing.
Yes I think this is great. When was the last time? Late 90s in the C/K and mid 90s in the K-blazer?
Part of me really wants one, though I don’t have a real justifiable need given the excessive price of these SUVs.
But they certainly are one of the best things going, and the best option in the truck segment!
The two go hand in hand, so I believe they are trying to keep oil consumption down by reducing EGTs, which helps keep the metallic oil additives out of the DPF.
This is the LM2, which I don't believe has the SCRoF. Correct me if I'm wrong.
Yes, they have to keep the metallic additives out of the DPF, but it also takes a lot of oil burning to plug a DPF with the additives from oil. I remember running into a calculator one of my previous mentors/technical experts on after-treatment systems created for calculating ash loading from oil additives in DPFs playing around with it. It takes a lot of oil to plug them in a reasonable amount of time.
I would hope the proper discussions happened between the after-treatment and engine development team to size DPF and what amount of oil consumption can be expected and or need to protect the DPF.
All versions of the 3.0L duramax (LM2 & LZ0) have an SCRoF. Source
Here is also a screen shot from GM's technical publication on the LM2
The LZ0 has an even more complicated after-treatment system than the LM2
Ah, so there are two SCRs, that's what I was seeing when I was under the vehicle. I thought there was only one SCR just after the downpipe. Thanks for the diagram.
That's right, those 6.2 or 6.5's are true dinosaurs now. 😆
These are excellent from everything I've seen so far. I think putting them in the SUV's was a good decision. 21's were rated at 460 pound-feet of torque at 1,500 rpm then throw in the 10 speed automatic it's icing on the cake. :cool: That's more than my 1995 7.3L Power Stroke (425 ft lbs) was although the F-250 obviously had more payload capacity. It is tempting for sure.
Is this engine made by Isuzu?
No, this is a clean slate design by GM. So far I am highly impressed with the torque, lack of turbo lag, and the fuel economy. The EGR also takes [most of the exhaust - corrected by @OneLonelyBurrito below] AFTER the DPF, so your engine isn't ingesting soot. Big design win.
What kind of mileage are you getting so far?
That was with a 25 MPH tailwind, but my normal cruising down the interstate is right at 30 MPG.
No, this is a clean slate design by GM. So far I am highly impressed with the torque, lack of turbo lag, and the fuel economy. The EGR also takes exhaust AFTER the DPF, so your engine isn't ingesting soot. Big design win.
FYI, it has two EGR systems. A low pressure one that pulls from behind the DPF and a high pressure from that pulls from before the turbo. The high pressure is mostly used during cold start and after-treatment system warm up. The rest of the time it uses the LP-EGR pulling from behind the DPF. So some soot is still getting into the intake system, its just a lot less. So overall, very big a win for keeping the intake clean.
When I drove the LZ0 in my brother's '23 GMC Sierra AT4, I was super impressed by it. The amount get pick up and low end torque were get impressive. Along with the responsiveness of it. It felt like it just always has power.
That is awesome. Hope the reliability and durability hold up.
We are long term Tahoe/Yukon owners - however this TD is never on the lot. One of my guys had to get one shipped from Michigan down south - and that’s a bit ironic since it was assembled in Arlington Texas 😶 - and motor up there …
Good read
https://gmauthority.com/blog/gm/gm-...is a,is an all-new design from the ground up.
I recently saw that oil on HPL's website and it did intrigue me. I will have to try it soon. Also I emailed Liam over at PPE about that filter and he stated that the efficiency at 10 microns is 50% and at 20 microns 85%. I would assume that would be better than the ACDelco offering.
So would that make the filter 99% efficient at 30 microns or 35 microns?
The 3.0 was actually designed by a German firm named FEV. That is probably why it doesn’t suck. GM however does assemble the engine.
Does anyone know if this HPL product uses an add pack that is also suitable for other Euro specifications? For instance, Mobil is covering DexosD, Porsche C20, VW 508/509 and MB 229.71 with their X2 0W-20.
On the other hand, Castrol is only covering DexosD and MB 229.71 with their Edge Turbo Diesel 0W-20 product.
It seems like some add pack suppliers are covering numerous specs while others are being more granular.
