2021 Chevy Duramax L5P - 25,233 miles/579 hours on oil - 46,733 total miles/1074 total hours - HPL 5w-40
wwillson
Staff member
Colorado
This run of HPL 5w-40 HDEO has a total of 25,233 miles and 579 hours on the oil and has been in service since 8/10/2022 (22 months). This sample has about 3,000 miles since the last sample and has only about 1,000 of those miles pulling and 2,000 miles driving unloaded on the interstate. I sampled at 3k miles because my intent is to change the oil to HPL's 15w-40 cold climate, which has zero group III base oil. The base oils for the cold climate oil are PAO, alkylated naphthalene (AN), and Esters. I am curious to see how the cold climate oil will hold up compared to the standard HDEO. My other motivation to change the oil now is to install the PPE fuel cooler relocation kit and run a much larger and frankly better engine oil filter. I would rather not change the oil filter for the duration of the oil run and I believe the PPE filter will allow me to do just that.
This UOA shows nothing but boring results. There has been 4 quarts of make-up oil over 25,000 miles, but as we have learned when you pull with relatively high EGTs you can expect some oil consumption. 1 quart consumption every 6,250 miles isn't bad, I would rather the consumption was zero, but that's not realistic. The Fe wear rate is 5.2 ppm/1k miles, which is in line with the wear rate we see from the 6.6L Duramax according to @dnewton3 's data on the Duramax. With the soot at 0.8%, TBN at 12.54, oxidation at 7.3, and the viscosity at 15.2, this oil is in great shape and would have continued to run if I didn't want to change to the 15w-40.
Sample Information
Sample Date6/23/202107/17/20218/24/20214/4/20227/1/20228/10/20221/18/20234/17/20238/16/20235/26/2024
Machine Age miles2,5002,7008,90016,00021,50021,55031,30037,00043,40046,733
Oil Age miles2,5002006,40013,50019,000509,75015,45021,90025,233
Machine Time hours55622143504954967348829971074
Oil Time hours5571522954401239387503579
Filter Age miles2,5002006,4007,1004,000505,0009,8008,4003,333
Oil ChangedYesNoNoNoYesNoNoNoNoYes
Filter ChangedYesNoYesYesYesNoYesYesYesYes
Make-up oil0001.5 qts2.5(+1)012(+1)3(+1)4(+1)
BrandFactoryHPLHPLHPLHPLHPLHPLHPLHPLHPL
Viscosity15w-405w-40 CK-45w-40 CK-45w-40 CK-45w-40 CK-45w-40 CK-45w-40 CK-45w-40 CK-45w-40 CK-45w-40 CK-4
Wear Metals
Iron1243667102166185132148
Chromium<1<1234<12244
Nickel<100<10<1<1<11<1
Titanium<1<1<1<1<10<100<1
Silver3<1<1<1<1<1<1<100
Aluminum<101513143891314
Lead6124312024
Copper109288518820329185197158128
Tin6106622223
Vanandium<100<1<1<1<10<1<1
Additives
Boron12015122163141702
Barium<1000004040
Molybdenum2514450504537541469574603560
Manganese<1<1<112<12222
Magnesium67299596810089249138311001936930
Calcium1260243924142557245923752111272226062551
Phosphorus1000109910291064981973847968916929
Zinc1155117911481285123311591078129212561242
Contaminants
Silicon87334846541821272728
Sodium753352581012
Potassium112435559616213028
Fuel %<1<1.0<1.0<1.0<1.0<1.0<1.0<1.0<1.0<1.0
GlycolNEGNEGNEGNEGNEGNEGNEGNEGNEGNEG
Soot%0.10.10.40.60.80.20.60.70.80.8
Fluid Condition
TBN8.5514.913.313.710.813.913.7612.8613.3812.54
Viscosity13.914.513.814.9714.514.414.514.515.215.2
Oxidation (normalized)0(40.6)2.5(43.1)3.5(44.1)7(47.6)7.3(47.9)
Excellent results.
Could have served longer, obviously.
Any idea what the Si starting point is? (IIRC the anti-foam package escalates this value).
Are you still using the fuel additive that has some Fe in it?
Sample Information
Wear Metals
Lead6124312024
Tin6106622223
Additives
Barium<1000004040
Contaminants
Sodium753352581012
Fluid Condition
Nice! Makes me want to run it in my gas truck, this or the supercar.
As you mention, there seems to be nothing out of the ordinary for your results on this latest sample. The only thing I see stopping this 25k ODI is right at the magical <150 Fe...Perfect timing! ha! Oxidation kept low during the run. Adding the 4 qts over the run probably helped a bit though. If this is a 12 qt sump then that's replenishing 1/3 of the oil. It'll be interesting to see how the 15w-40 PAO fairs & sounds like it has a good starting point but this oil used here seems to be excellent as well.
This is correct. When you replace 4 quarts of a 10 quart sump, it skews the data. This oil could easily run to 30k and probably 35k if I didn't mind > 1% soot. I still haven't made up my mind on that one.
Is there a PDS for the cold climate 15w40 that we could see?
I don't have the PDS for this, but here is the data table for the 15W-40 Cold Climate. Once I complete the PDS I will upload that as well.
are the newer Duramaxes worse on oil? My 04 with 200K @9K had iron @7PPM, so that’s .8 per 1K, much lower than yours.
As the Duramax engines progressed, they put out more power and more heat. We have a 2002 Duramax (LB7) at home and I don't think you could make it use oil. It has 300 HP and 520 lb-ft torque. The L5P has 445 HP and 910 lb-ft torque from the same 6.6L. Piston crown temperature is the issue with oil consumption. The L5P will sustain 1350F EGT all day long. That makes for super heated pistons and evaporative oil lose. If I used my truck as a car it would almost certainly have less Fe in the oil. All my truck does is pull a heavy, tall trailer.
I’m not talking as much about oil consumption but more how much FE the engine is producing.
I understand that it’s used like a truck. My 04 made a real long run going from Texas to Fairbanks Alaska pulling a 39 ft 5er. The entire run was 5566 miles with zero oil added. During this run the FE came in at 8 PPM, so significantly less that what you are seeing…that’s why I asked as they seem to be harder on oil.
@dnewton3 did a study on the Duramax, let's see if he has any data showing the L5P making more metal.
