Honda Civic EX 2006, original owner.
run MM to 0%
WIX OIL ANALYSIS REPORT
DATE SAMPLED 28-Jul-12
DATE RECEIVED 06-Aug-12
DATE REPORTED 07-Aug-12
SIF NO.
TIME ON UNIT 82277 Mi
TIME ON OIL 8100 Mi
OIL BRAND Mobil
OIL TYPE Mobil 1
OIL GRADE 5W20 SM
OIL ADDED none
FILTER PureOne
OIL CHANGED yes
WO NUMBER
Metals (ppm)
Iron (Fe) 12
Chromium (Cr) Lead (Pb) Copper (Cu) 1
Tin (Sn) Aluminium (Al) 11
Nickel (Ni) Silver (Ag) Titanium (Ti) Vanadium (V) Contaminants (ppm)
Silicon (Si) 21
Sodium (Na) 15
Potassium (K) Coolant No
Additives (ppm)
Magnesium (Mg) 23
Calcium (Ca) 2530
Barium (Ba) Phosphorus (P) 760
Zinc (Zn) 870
Molybdenum (Mo) 199
Boron (B) 51
Contaminants
Water (%) Physical Tests
Viscosity (cSt 100C) 7.9
Physical / Chemical
Base Number (mgKOH/g) 2.5
One qt was EP, never oil added.
Air filter was recently changed.
Most trips < 10 miles.
First of 5 WIX kits from Amazon deal.
Spaces and tabs did not work above?
run MM to 0%
SIF NO.
TIME ON OIL 8100 Mi
OIL BRAND Mobil
OIL TYPE Mobil 1
OIL GRADE 5W20 SM
OIL ADDED none
FILTER PureOne
OIL CHANGED yes
WO NUMBER
Metals (ppm)
Iron (Fe) 12
Silicon (Si) 21
Sodium (Na) 15
Additives (ppm)
Magnesium (Mg) 23
Calcium (Ca) 2530
Zinc (Zn) 870
Molybdenum (Mo) 199
Boron (B) 51
Contaminants
Physical / Chemical
