I bought a used 2013 Ford Edge. I changed the old very soon after purchase, and decided to do an oil analysis when the new oil was changed. I used Castrol Edge 5w20 High Mileage oil and a Mobil 1 oil filter because they were on sale. This change I used Castrol Magnatec, which I plan to use from here on out if the next analysis looks good.
2013 Ford Edge
38611 total miles
7350 miles on oil
1 year 3 months on oil
WIX OIL ANALYSIS REPORT
______________________________________
DIAGNOSIS
All wear levels appear within acceptable limits for first
sample. Silicon level (dirt/sealant material) satisfactory.
Water content acceptable. Viscosity within specified
operating range. Action: As oil already changed,
resample at next recommended interval to monitor and
establish wear trend.
Unit No. Edge 1
ANALYST: roldan.beldad
OIL ANALYSIS REPORT
LAB NO. 42021350391
DATE SAMPLED 15-Sep-19
DATE RECEIVED 25-Sep-19
DATE REPORTED 26-Sep-19
________________________________________
METALS (ppm)
Iron (Fe) 8
Chromium (Cr) Lead (Pb) Copper (Cu) 19
Tin (Sn) Aluminium (Al) 5
Nickel (Ni) Silver (Ag) Titanium (Ti) 22
Vanadium (V) _________________________________________
CONTAMINATES (ppm)
Silicon (Si) 14
Sodium (Na) 2
Potassium (K) 3
ADDITIVES (ppm)
Magnesium (Mg) 900
Calcium (Ca) 858
Barium (Ba) Phosphorus (P) 524
Zinc (Zn) 704
Molybdenum (Mo) 67
Boron (B) 27
__________________________________________
CONTAMINANTS
Water (%) Coolant No
PHYSICAL TEST
Viscosity (cSt 100C) 8.7
PHYSICAL / CHEMICAL
Base Number (mgKOH/g) 4.6
2013 Ford Edge
38611 total miles
7350 miles on oil
DIAGNOSIS
Unit No. Edge 1
OIL ANALYSIS REPORT
LAB NO. 42021350391
METALS (ppm)
Iron (Fe) 8
CONTAMINATES (ppm)
Silicon (Si) 14
Sodium (Na) 2
Potassium (K) 3
ADDITIVES (ppm)
Magnesium (Mg) 900
Calcium (Ca) 858
Zinc (Zn) 704
Molybdenum (Mo) 67
Boron (B) 27
CONTAMINANTS
PHYSICAL TEST
PHYSICAL / CHEMICAL
