This is my first oil analysis on this vehicle. We've owned this one since 2018 and 95k miles. It was a high-mileage, well-maintained fleet vehicle before we got it. Never really had a reason to pull a sample on this one until now.
For the last few OCI's I've just used the Castrol EDGE Extended Performance and changed it when the OLM got close to zero. This time it was down to about 12% but the oil level was significantly above the full mark. Best guess is that it was showing at least 2-3 quarts over full.
I hadn't been monitoring it as closely as I do some others because there was never really any reason to. The oil level on this vehicle was always pretty consistent, but would gain oil slightly over a 10k OCI. It's a direct injection (only) engine, so some dilution is to be expected. This time it was way over the normal amount, and I changed it as soon as I could when I saw the oil level had risen like it did. I'll have to be better about monitoring this one going forward.
My takeaway from this report, though, is that some fuel dilution (even relatively extreme) is not a big deal. Wear metals are low indicating that the Edge Gold EP is very capable of handling some dilution. The viscosity is low, as you'd expect with dilution. It is well down into the 20-weight range, but it looks like the engine doesn't care much. It could probably be quite happy on a diet of 5w20 if not for the fuel dilution.
Future maintenance plan for this one is just to monitor the oil level and change the oil when it starts showing at the top of the full mark. Forget about the miles. When the oil level gets too high, I'll change it out and keep motoring on. I may use the cheaper Castrol Edge in the black bottle instead of the Gold EP if the intervals start getting down around the 5,000 mile mark. I see no need to use and EP oil for such a short OCI. But with that said, the EP did well with pretty severe dilution, so maybe the EP is still the way to go.
I could be convinced either way.
