This oil was put in at a little over 120K and taken out at exactly 130,000.0 miles. It is the Amsoil 0W-30 Series 2000. The filter is an Amsoil EaO30 which is a little longer than the OEM spec'd filter. There are a lot of variables with this OCI but I ran the sample anyway just to see how the oil held up. There was a K&N air filter installed for the first 7,000 miles until I took it out and replaced it with an AC Delco paper element. I also added 6 ounces of VSOT at 7,000 miles. So the new air filter and the VSOT were in for about 3,000 miles. The truck was used for a mix of highway and city for the first 7K and mostly highway on vacation for the last 3K.
The sample did not look bad except the TBN was depleted and I think I reached the limit of the oil in this V8 engine. I left the filter in but changed the oil to Amsoil ASL 5 qts and the rest VP racing 5W-30. Universal averages were for wear levels after an average of 5,085 miles:
Sample/Universal
Al 5/4
Chr 1/2
Fe 22/24
Copper 9/64
Lead 18/9
Tin 0/1
Mo 65/50
Nickel 1/1
Manganese 1/2
Silver 0/0
Ti 0/0
Potasium 3/1
Boron 11/57
Silicon 13/13 (surprised not higher due to K&N)
Sodium 9/9
Calcium 2651/1680
Magnesium 16/387
Phos 599/789
Zinc 725/955
Barium 0/0
SUS visc 66.3/55-67
Flashpoint 380/>375
Fuel Antifreeze 0/0
Water 0/0
Insolubules .3/ TBN 1.0
I am switching to ASL 5W-30 for one run then I will either go to HDD 5W-30, ATM 10W-30, or XL 10W-30. Originally I was thinking about running one year (15K) on this oil but, after listening to advice on BITOG I decided to only go 10K and then to run this sample. I think that was good advice since it appears 10K is about the limit with this engine (just due to the low TBN). I would like to run the HDD but I doubt if I would get too much more than 10K out of it but I still may run it.
Overall, I think it looks like a pretty good UOA for 10K miles although I think it might not have looked as good if I went much past 10K. I'm a little surprised at the low TBN though.
Sample/Universal
Al 5/4
Chr 1/2
Fe 22/24
Copper 9/64
Lead 18/9
Tin 0/1
Mo 65/50
Nickel 1/1
Manganese 1/2
Silver 0/0
Ti 0/0
Potasium 3/1
Boron 11/57
Sodium 9/9
Calcium 2651/1680
Magnesium 16/387
Phos 599/789
Zinc 725/955
Barium 0/0
SUS visc 66.3/55-67
Flashpoint 380/>375
Fuel Antifreeze 0/0
Water 0/0
