This is from a 1993 Chev 1/2 ton extended cab p/u. The oil is Amsoil 0w30 and has been run for 10,297 miles. The engine had a small coolant leak and used about 1 pint of Anit freeze in 8 months. I had both OAI and Blackstone run the UOA, plus I had blackstone do a particle count on the EAO filter - Vehicle also had the EAA air filter. 106395 on unit at UOA time.
-------------------Blakstone------------OAI-----Black/Avg
Aluminum-----------7--------------------15------3
Chromium-----------0--------------------1-------1
Iron---------------22-------------------26------15
Copper-------------6--------------------11------5
Lead---------------10-------------------18------8
Tin----------------0--------------------0-------1
Moly---------------19-------------------25------63
Nickel-------------0--------------------0-------0
Manganese----------0--------------------N/A-----1
Silver-------------0--------------------0-------0
Titanium-----------0--------------------0-------0
Potassium----------30-------------------0-------7
Boron--------------8--------------------14------38
Silicon------------33-------------------51------18
Sodium-------------27-------------------36------10
Calcium------------2816-----------------3175----1896
Magnesium----------15-------------------28------160
Phosphorus---------644------------------853-----734
Zinc---------------751------------------1008----887
Barium-------------1--------------------0-------1
SUS Visc 100c------68.0---------Cst100c-12.94
Flashpoint---------395F-----------------No
Fuel--------------- Antifreeze---------?--------------------No
Water--------------0.0------------------No
Insolubles---------0.3------------------No Data
TBN----------------2.1------------------2.73
Oxid---------------No-------------------16.0
Nitr---------------No-------------------25.0
OAI flagged Silicon & TBN as abnormal & said change
Blackstone flagged Alum,Iron,Potassium,Silicon and Sodium and said change oil. And reccommended a 7k interval.
Blackstone particle count ISO Code 17/16/14
>=2m-----2045
>=5m-----757
>=10m----209
>=15m----81
>=25m----19
>=50m----1
>=100m---0
Any thoughts!
Thanks
>=2m-----2045
>=5m-----757
>=10m----209
>=15m----81
>=25m----19
>=50m----1
>=100m---0
Any thoughts!
Thanks
