Originally Posted By: hatt
Originally Posted By: CATERHAM
But then you're the guy always talking about running ultra thin oils that inherently have lower HTHS. You've yet to show slightly higher VI leads to tangible benefits inside the engine.
I don't consider a 0W-20 an "ultra thin oil", and the reason I can run that grade in a couple of cars is because my oil temp's are well contained. If I was seeing sump oil temp's of 150C you can bet I'd be running a 0W-40 although I would do everything possible to reduce my oil temp's to a more sane level with oil coolers first if I could, so that such a heavy oil was not necessary.
I appreciate your point about the 20 point VI difference between PP 5W-30 and 10W-30 and I would add in your favour that PP 10W-30 likely has a slightly higher VI than PP 5W-30. But the difference is there and given the choice I would choose the 5W-30. Having said that, I wouldn't buy PP 5W-30 either but rather PP Euro LX 0W-30 which has both a 3.5cP HTHSV and a 204 VI. So not only is it lighter than PP 5W-30 (and way lighter than the 10W-30) at temp's as high as 90F but has a much higher HTHSV to the 10W-30.
