Quote:
I think that Shell V-power has the highest level of detergents and they do advertise (and we all know that makes it gospel) that it will clean a dirty engine. Stick with Top Tier fuels and you'll have nothing to worry about.
Quote:
Just for the sake of argument...
I think that Shell V-power has the highest level of detergents and they do advertise (and we all know that makes it gospel) that it will clean a dirty engine. Stick with Top Tier fuels and you'll have nothing to worry about. Given similar prices, I will choose Shell V-Power when purchasing premium.
As for oil, why is it that if one takes a used car that has "black" oil and changes/flushes the oil multiple times the will often eventually stay "clean." Synthetics are known to "clean" out gunk and expose leaks that were hidden/plugged by conventional oils. It seems that it is reasonable to assume that some oils "clean" better than others. Maybe the synthetic MaxLife would be the ultimate brew for this?
Depends on the basestock Esters, yes pao, no.Quote:
I am going full syn almost solely on this post. Wow. Synthetics have the potential to clean is all I needed to heat.
Quote:
If you want oil to clean, go ester like Redline. Will take some time though.
Isn't calcium a multifunction additive that also serves for detergent? Maxlife has a lot of calcium.
BTW, I don't know that it is worth using Maxlife Synthetic, when regular Maxlife Blend is already so very good (part PAO, high calcium, seal conditioners, 300 ppm moly, etc).
Quote:
I'm using maxlife in the wifes toyota so far it runs the same as the "weak additive pack" valvoline ac that it ran the first perfect 100,000 miles on...
