Still having oil Detergents confusion....
Or they should publish all these "hidden" additives we hear about on here.
The average consumer of their products will have no idea what they are looking at, and they don't exactly want to share their secrets with their competitors either, so you'll never see this happen.
But couldn't oil testing companies figure out the additives?
Sure.
Just as soon as Coke releases their formula, we can expect the oil companies to divulge exactly what they use and in what proportions…
But they publish performance specifications. Why do you think you need to know the additive levels and which additives are used?
Are you a chemical engineer that can accurately asses the relative performance and the appropriate level of additive?
Sure.
Not oil companies. The oil testing companies. They list other additives in their reports
They list elements not complex compounds which is orders of magnitude more complex and difficult to do. If you want them to reverse engineer and detect specific chemicals, then it's going to cost you hundreds of thousands of dollars and take six months instead of 30 bucks and a week for the post office to deliver it.
So some group 5 oil in the mix does the cleaning not detergents.
Seems silly to call Calcium/magnesium detergents if they don't actually clean. So confusing.
Detergents prevent contaminants from plating out; keep them in suspension. Dispersants prevent them from agglomerating, which would allow them to overwhelm the detergents and fall out of suspension. These two things work together to prevent deposits. If we are talking about an emulsification like sludge, which hasn't adhered to a surface (unlike varnish) then the action of agitation of the oil flowing over it is enough to break some of that up, which then gets put in suspension in the oil.
If something with high polarity and/or solvency is also in the oil, like some esters or AN's, then the oil can actually work to slowly remove existing deposits from surfaces.
I keep reading conflicting information on detergents in motor oil. Some sources say they clean, others say they keep deposits from forming on surfaces. Can they do both, or which is it? Does one do a better job then another?
What in motor oil actually cleans up old deposits? Is it the base oils used?
Oh god! Not again
Detergents (in this sense) are focused more on prevention than cure. They come in the form of calcium sulfonate and magnesium sulfonate (most commonly), the core of which is a calcium/magnesium carbonate salt. These are the same carbonate salts found in common OTC medications Tums and Milk of Magnesia. The same way they neutralize acids in your gut that cause heartburn and indigestion, they neutralize acids in the oil that cause oxidation and corrosion. They're primary purpose is to keep the oil clean, not to clean the engine. Along with dispersants, they also keep contaminants in suspension to prevent agglomeration somewhere harmful.
Certain esters are good at cleaning and is the preferred method. They do so slowly so as not to clog the pickup screen or oil galleys. Products like High Performance Lubricants SAE 30/40 Engine Cleaner use these esters for that purpose.
I was going to suggest to him to look up detergents and dispersants which might help but you explained it best.
So detergents are more like Scotchgard then a true detergent.
used oil analysis don’t actually publish additive levels.
They publish the levels of basic elements.
Big difference.
While technically true their source is still labeled by the labs who provide the used oil analysis as "Detergents". We then remark how different formulations have different levels of these elements which people then infer as differences in the comparative amount of additive or differences in formulation (ex, SP vs SN). Without this segment of the used oil analysis a lot of what is spoken and worried about on BITOG would vanish.
