Still having oil Detergents confusion....
Michigan
I keep reading conflicting information on detergents in motor oil. Some sources say they clean, others say they keep deposits from forming on surfaces. Can they do both, or which is it? Does one do a better job then another?
What in motor oil actually cleans up old deposits? Is it the base oils used?
Detergents are there to prevent deposit formation. They can clean up sludge, but are not sufficient to solubilize varnish films. @OVERKILL has a nice flowchart that helps delineate the difference between sludge and varnish. Significant solubility is generally achieved by incorporation of specially engineered Group V base oils.
So they do in fact clean, not just suspend contaminates. Would this include carbon deposits on pistons/rings?
There's detergents and there's cleaning. The metallic compounds like calcium, magnesium, etc in motor oil are there mostly to keep particulates in suspension and prevent them from adhering to the internal engine surfaces. They do little (but not nothing) to remove already adhered particles (sludge).
Esters on the otherhand can be more effective at removing sludge which is why some oils are better than others at removing sludge and varnish.
So how do oils show they clean up pistons and oil rings? What is doing it?
[It's] generally achieved by incorporation of specially engineered Group V base oils.
IIRC Alkylated naphthalenes (AN) (Grp 5) can remove varnish
Usually carbon deposits are adhered to the metallic surfaces and adjacent grains by varnish.
So some group 5 oil in the mix does the cleaning not detergents.
Seems silly to call Calcium/magnesium detergents if they don't actually clean. So confusing.
I was thinking more of heavy deposits or deposits on pistons/oil control rings. Many oils claim they can clean them up and keep them clean. Like Valvoline Restore and Protect.
We you don't know what they're using and a used oil analysis doesn't show everything anyways so it's a rather pointless exercise.
Its a right title-- they are detergents. But not even Tide gets rid of all my stains, so my expectations just need realigning, I guess.
I kinda wish used oil analysis didn't publish additive levels but without them what would we bicker over?
used oil analysis don’t actually publish additive levels.
They publish the levels of basic elements.
Big difference.
"Many"?
The devil's in the details of their wording.
Most products are built to fit a spec. The specs are a game of deposit prevention. There's no onus to have varnish removal performance.
