I've used Valvoline for years too, worked great in my last car (no sludge at all, even with a poor history before I purchased it). Never had a single engine problem.
Actually, I think you got me to thinking about this detergent product. Since I like SLOB so much, I figure the oil detergent stuff maybe is good. Hey, I looked at a bottle recently and on the back it said if the engine is pretty dirty, you could use two bottles at once. I'd like to give it a try, but failed to load up on it when Big Lots had it cheap. No it is $4 a bottle, though Murrays has 2 for 1 on it right now.Quote:
tellpaul, this is the first time EVER i have seen someone talk about cd-2 oil detergent other than me.
have you tried it?
Quote:
i've heard somethings about maxlife that are scaring me a bit. For example: 1 of the techs said that if you use valvoline maxlife for a while, and switch to another brand of oil, the seals will leak because the maxlife enlarges them, and they decrease in size when you discontinue use.
I've also heared people claiming a very light 'protective layer' on internals from using maxlife...i don't want any 'layer' in my engine.
The effect of Maxlife on seals should be similar to that described for AutoRx. If the seals are crud encrusted, the Maxlife will have to clean the crud off before it can really condition the seals. If the crud was forming false seals on aged seals that are somewhat hardened and perhaps shrunken from age, then cleaning the crud off will result in a leak. As the Maxlife conditions the cleaned off seals they should be partially restored to a more pliable condition, which should also allow them to return to their original (pre shrunken) size and thus eliminate the temporary leaks. As with AutoRx, if there are physically damaged seals, then there is no help. Also, I would not expect every vehicle that runs Maxlife to experience a leaking phase. I rather think it is infrequent and happens more on older cars and/or those with very high mileage (as time and use both age seals). I don't see that they should decrease in size after discontinuing use of Maxlife (any more that any seal may decrease in size as a normal part of the aging process).Quote:
Anyone else know of this to be true? Geez...I just started using Maxlife, then I hear this #@$%!!
