I'm not strictly a thick oil pusher. Even though I use 0/40 in my Navigator, I'll tell anyone in the world that there is no reason on the planet aside from VVT clattering to use a 5/20 oil. I used conventional 5000-mile 5/20 for almost 11k miles in my Navigator, proceeded to continue carrying overloads and drive like a demon, and my 5.4's UOA reflected that the engine cared not what was done to it.
I'll say straight out that where the 5.4 3V with properly operating valvetrain and oil pump is concerned, you can get absolutely no benefit at all from either thickening the oil, or using a synthetic. Money down the toilet.
My Porsche? Spec 0w-40 Castrol(even though I could have done 5w-50)
Lexus? Spec 0w20 TGMO
Benz? Spec 0w40 Mobil/Castrol
Every diesel I have has spec oil viscosity, unless spec is no longer available
etc, etc etc
So where do I play around with viscosity? Usually engines that are known to have received an improper oil spec (marine, it happens a LOT), where an engine is being used under extreme circumstances, or where the engine's manufacturer has played around with viscosity by condition or model year.
Sometimes, there is nothing to be had by changing the vis. Sometimes, changing the quality or durability of the oil is what gives improvement, rather than vis. But in any case, I am always looking for a result.
Sometimes those results can be seen in a UOA. Sometimes those results can be seen looking at the parts of an engine spread out all over a table. Sometimes those results are more obvious in that something that should have died no longer fails.
So I am not necessarily a thick oil person. I am a person who understands all too well that sometimes a manufacturer enslaves themselves to an oil spec ideal for some unknown reason, and it does not work out.
etc, etc etc
