Not sure if you guys have it down there, but in Atlantic Canada where tons of salt is used on the roads every winter, lots of people go with Rust Check. Similar to Krown, they saturate the underside of your vehicle, do the insides of every door opening, under the hood, and they drill little holes in your rockers and sometimes doors and insert a sprayer rod that coats the inside of the panel as well. They plug the holes with little rubber plugs, and if you didn't know better it looks factory. Out this way, if you see a car that's more than 15 years old still on the road that isn't rusted to ****, it's very likely that it will have a row of Rust Check stickers across the rear window. My family has used it for years with great success.
