Originally Posted By: Trav
I am still thinking an engine mount is weak or possibly a spool valve getting clogged or sticking, my money is on a bad rear mount, 1 min driving it and I could tell you mount or not after changing more of them than I care to remember.
Oil to the spool valve can also be restricted at the oil filter mounting pad, most of the time it will throw a P300 with CEL and VSA light also lit but not always. Hey if its running good and smooth leave it in peace and forget the thing even had VCM.
Varnished spool valve.
Deposits in filter mount and block.
Clogged filter screen against new one.
Cleaned parts ready to be reinstalled.
Thanks Trav!
I did look for the rear engine mount and I'm not sure if I'm looking at the right area. Is it easier to see it from underneath the car? I have change the oil in my car since new every 5000 miles using mobil 1 0w 20 and a OEM or NAPA Gold(Wix). Oil always came out really clean and oil analysis showed low insolubles so I'm hoping the engine has no sludge or any parts clogged up. Looking through the oil fill hole All the metal parts are bright and shiny with no signs of varnish at all. Also when changing the oil filter where it screws on is also bright and shiny with no varnish coloring.
Thanks Trav!
