t1snwrbrdr12
Another question…
Can VCM be disabled with a Honda scan tool or a high end scanner such as certain Autel’s / etc?
K TunerWhat tuner did you end up with?
Thanks for that. How many resistors did they throw in? Values?
Smart! And thanksNot sure the common ones that works are 100 and 80. I had the 100 for a while it caused a CEL when it got cold. Put in an 80 and it’s been solid. I just got a pack of resistors on eBay for less than 2-3 bucks. I’m not paying 80 or up for a wire connector and resistors
The problem is resistance needs to change based on ambient temp...the new tuners do this automatically and you aren't stuck with one single number that may or may not be best at those conditions. The older ones offered 10 different resistors that were easily selectable. Somewhat depends on climate, but I see temps as low as -25F and as high as 100F here which demands versatility.Not sure the common ones that works are 100 and 80. I had the 100 for a while it caused a CEL when it got cold. Put in an 80 and it’s been solid. I just got a pack of resistors on eBay for less than 2-3 bucks. I’m not paying 80 or up for a wire connector and resistors
Thanks. true- but depends how sensitive the ecm is to this temperature range. If its not, probably not much impact. A quick calculation shows only about a 0.28 ohm change in those temperatures you experience, anywayThe problem is resistance needs to change based on ambient temp...the new tuners do this automatically and you aren't stuck with one single number that may or may not be best at those conditions. The older ones offered 10 different resistors that were easily selectable. Somewhat depends on climate, but I see temps as low as -25F and as high as 100F here which demands versatility.
Nope. Scan tool software is basically reverse engineered from OE, and Honda definitely doesn't want it to be disabled, whether it's better for the engine or not.Another question…
Mine is 2009, but I'm very happy with S-VCM. Almost 30k miles with it. Glad I didn't waste money on the cheap resistor type, and also glad I didn't go for the more expensive VCMTUNER II, since S-VCM does exactly the same thing. But for less, and in smaller package.We just got a new 2024 Odyssey, and, even though a lot of people say that the VCM Gen 3 (which is what ours has) doesn’t cause the problems that the previous generations of VCM did, I’m still strongly considering disabling it.
From some brief research, it sounds like the S-VCM is the way to go, due to the fact that it allows the display of true coolant temp when/if an overheat occurs.
And I know at least 1 member, @RooflessVW is using one on his 2022. Have you had any problems from it?
So is there a consensus? Any disadvantage to the S-VCM, or reason to use a different brand?
Tis true that Gen3 hasn't and doesn't cause as many problems but muzzling it > not muzzling it.We just got a new 2024 Odyssey, and, even though a lot of people say that the VCM Gen 3 (which is what ours has) doesn’t cause the problems that the previous generations of VCM did, I’m still strongly considering disabling it.
No issues to report. I'm at 30k miles.We just got a new 2024 Odyssey, and, even though a lot of people say that the VCM Gen 3 (which is what ours has) doesn’t cause the problems that the previous generations of VCM did, I’m still strongly considering disabling it.
The VCM MUZZLER offsets ALL of the temperature readings, by whatever the size of the resistor is. So temp could be critical, but gauge may say "normal". These are heavily affected by weather and altitude.The VCM muzzler intercepts the temp signal to the computer and spoofs the temp just below the min required to enable cylinder deactivation. The unit still knows the real engine temp and will pass the real temp to the computer if it reaches dangerous levels.
It’s simple, easy, and worth it, in my opinion.
I've been running Castrol HM 0W-20 in mine since new.Thanks guys, I’m sold.
I’m going to go ahead and order an S-VCM for the wife’s new Odyssey!
Now, for the big decision…oil! One thing I know for sure - it won’t be getting a 20 grade.
