Leaves stuck in the front fender
Chicago
I dont know what the area is exactly called.
Its visible in the door jam. Behind the fender, a lot of leaves get stuck in there and often times sunroof drains and etc. Normally this is the cause of rust, because leaves and junk get in there. Most cars you get reach it with a screwdriver. My infiniti is special, its blocked for the most part. I see a little opening and a twig or two. Plus i see the beginning signs of rust. Is there any simple way of reaching that area? Short of removing the fender or shooting air in there.
You can easily remove the fender liner or just unscrew the part of the fender liner thats closes to the door and all that stuff will fall out.
