Originally Posted By: dailydriver
Can the dash light/DTC be 'written out' of the ECM with the Mountune/Cobb Accessport software/devices, IF one wanted to totally remove the motor??
I would think so, I think that is one of the workarounds available. A lot of guys have aftermarket intercoolers and the first part of the install is to remove the grill shutters & motor for the additional space. And I know they are not all driving around with the grill shutter code setting all the time.
I do know most of the tunes for the ecoboost motors set the shutters to 100% open all of the time, if you happen to leave them installed. Heat soak can still be an issue after a good pull on these things and the last thing you want is the shutters closing off the airflow.
Originally Posted By: JetStar
I'd have to assume that with all the sensor data available, that the shutters would be scheduled to suit the needs of engine cooling, intercoolers, and environmental control systems precisely. It would be interesting to have a look at the code, or even some streaming data for commanded position.
You would think they would not be intrusive to the intended use of the car but on the STs they block off the intercooler as well as the a/c and radiator creating major heat soak, pulled timing and reduced power. Not to mention the risk of overheating if they do not function properly. They are quite flimsy as well you can see the pictures above. You can push down in the middle of each individual shutter, bend it in half with one hand and it pops off the track. It took me 30 or 40 seconds to remove all 12 from my car. I understand the need to squeeze mpg out of a vehicle but they could have left them off the performance version.
