Yep,
I had the dealer add that with Mobil 10W30 at this oil change. BG's products have recieved many positive comments from this board...BG44K in particular.
By itself with Mobil 1 the car valvetrain is a little more noticeable.
After adding the BG MOA to 5.0qts Mobil the idle is much more smoother...to an already smoothe engine.
In addition as according the oil pressure electronic guage at HOT temp the Mobil 1 is not loosing pressure at idle either. Perhaps this fluid is adding some kind of viscosity stabilizer as well?
BG MOA is a thick red fluid. I will run a UOA when this cycle is completed. Mobil 1 is supposedly Zinc defiecient which BG MOA makes up for.
