As a resident BMW-aholic, and one who has experienced significant sludge in each engine currently in my stable (M52tuB28, M54B25, M62tuB44) as well as numerous other BMW engines, I can share anecdotes...
All 3 cars were bought used with fairly low miles and full service histories, including dealer oil changes that seemed to vary randomly between BMW Syn, GC, and M1. Most were 12-15k intervals, and a few changes were done at indie shops.
All 3 engines had sludge and varnish, a significant amount IMHO. As I did not want to add any miracle additives, I researched other methods and settled on one. This was with my 328Ci, the first one of the three I purchased. I knew it was going to become modified (although at the time, no idea HOW modified it would end up), and I wanted a "clean" start.
I went to the autoparts store and picked up 10x5qt tubs of Royal Purple (a mix of 5w30 and 5w40) and 12 K&N Oil Filters.
I ordered 10qts of Redline D4 ATF (trans and PS), 6qts of Redline 75w90 for diff, and 28qts of Redline 0w30 oil along with 8 AFE oil filters.
I did use a bit of Seafoam through brake booster, PCV, SAP, gas, throttle body (with manual cleaning), and about a total of 6oz in crankcase (6.5qt sump, for 200mi).
Dropped the oil while still hot, ran some PP for 500mi to ensure the Seafoam was out (did not know it was a good cleaning oil at the time), and then let that drain for 40min immediately after a 40min drive (plus the 5min cooldown to get it on jacks).
Did the following:
- 2k mile OCI with RP and hard driving, oil came out BLACK
- 2x 2k OCI with RP, changing filter at 1.5k (BLACK)
- 2x 3k OCI with RP, changing filter at 1k/2k (BLACK)
- 2x 3k OCI with RL, changing filter at 1.5k (not as black)
- 1x 6k OCI with RL, changing filter at 1.5k/3k/4.5k
After that, I have stuck to RP and Redline as even though I was modding the car during this time (thus it would sit for weeks without driving at bodyshop and such), when I tore open the engine for a bottom and top end bigtime upgrade prior to S/C install, there was literally not a single bit of sludge. It wasan aggressive way to treat the issue in terms of how many OCIs but at the time I did not know better. Could have had similar results with doubled mileage per OCI with same OF change intervals.
Still, it removed POUNDS of sludge and varnish from everywhere, and a boroscope showed the oil passages to be literally spotless. Granted, this was early in the car's life mileage-wise, but the results were astounding.
I have done similar with 325i, except longer OCIs (6-7k w 2 filters per OCI) and when I changed the valve cover gasket at 148k a few months ago, it was amazing how clean it is, especially considering mileage.
It still has a little ways to go, as the Oil Level Sensor has gone from Always On to only on for first 30-120s after cold start. Seeing as it completely cleaned my 328's OLS, I figure a few more runs is worth it before buying a new sensor.
Doing a teardown after 10k on 328Ci (10k after Ti valvetrain, Schrick cams, Mahle forged pistons, Carrillo forged rods, blueprinted/razor edged crank, ARP bolts everywhere, ported/polished head, custom Intake mani, ESS TS2+ TwinScrew SC+IC w customization, and more), to see how everything was holding up considering actually slightly higher than stock compression and a minimum of 16.5psi boost on 93oct street (22psi+ 105oct race), and dozens of track days and autocross events... All with RP or RL in the sump (capacity increased to approx 9qts due to baffled pan and SC plumbing)...
Every single part looked brand spankin new. To this day, I run the car like a madman and it has never once worried me.
Other oils may do as good of, or better, job cleaning, but the combination of cleaning and protection even under what constitutes several levels beyond "Severe Service" (abuse?) has me a believer.
It worked for me, it works for me, and I see no reason to change it.
Just wanted to relay my experience with Bavarian Sump-Gunk, and how I rid my cars of the stuff.
