- Joined
- Dec 10, 2023
- Messages
- 65
Hello everyone, prepare for a bit of a long post here.
I have a 2013 RAM 1500. It has been trouble free until October.
One night i got in it to take it on a drive. Truck has always had a cold start tick that got better when it heated up from a broken manifold bolt on the passenger side i never cared to fix.
I noticed the tick was a bit louder, not too much louder, but didn’t care much about it and drove off. After coming home and letting the vehicle cold soak for a few hours, i started it up, and its ticking noticeably loud and the noise does not improve at all when it warms up.
I then started with the process of elimination. I noticed that there was a ticking when the engine was cranking in flood mode that was very noticeable with the engine cold, meanwhile, cranking in flood mode after the vehicle was off resulted in no tick (just in flood mode.)
Then, I popped open both valve covers, replaced all lifters/rockers, sound got a tiny bit better (wasn’t as sharp cranking in flood mode while cold) but while it was running there was 0 change.
Then I ran a compression test, all cylinders ranged from 135-145PSI. I removed the plugs, got a boroscope camera into the cylinders and saw no mechanically made valve reliefs on the pistons, no cylinder bore wear (as you’d expect from a bad wrist pin/skirt slap) and everything looked to be in good shape.
Then, i removed the timing cover, observed that the chain was a bit loose on both sides after the engine was off for around 3-4 days due to the hydraulic tensioners not having any oil pressure to tension down the guides. Once it ran for 15-20 seconds, the guides/chains would be stiff and rock solid again.
Thinking it was a piston skirt or something else related to the bottom end, i dropped the oil pan, found absolutely 0 metal in the pan, 0 movement in the rod bearings, and from what i could tell, no movement in the wrist pins and no sound when i had someone cranking the engine via the crankshaft pulley when i was under the vehicle. There was also nothing wrong with the piston skirts.
Also noticed after buttoning it up and running it after checking all i could that the noise goes away completely when you let off the gas at cruising speed, a bit like how an exhaust leak would. The cranking also changes pitch when it’s cold vs warm, sounding a bit more like it’s low on compression across all cylinders when it’s hot despite the compression remaining the same cold vs hot. Noise is much louder with engine sitting at idle and goes away a bit when it’s at around 1500+ RPM.
Here are some videos:
4.7 Engine Tick
4.7 Cold Crank Tick
4.7 Warm Crank
4.7 Engine Tick
4.7 Cold Crank Tick
4.7 Warm Crank
